Thread: AC Issues
Results 1 to 10 of 10
  1. #1 AC Issues
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, when I bought my car a few months ago the guy said it just needed the AC charged...., ha, really. So, a couple months back my brother charged my AC - and you could hear a very distinct sound of a leaking hose (kind of around the front left side of the car I think) - but the AC blew cold top and bottom while there was still Freon in the system. A few weeks later I noticed that my feet were always getting hot, so I felt down by the bottom vents and lo-and-behold they were blowing heat. All climate control is off. So..., my compressor and blower should be fine because while there was Freon in the system it blew AC just fine, right? If not I got two spares of each from parts cars. But this leaking hose I heard, where could that be located? I didn't think it sounded like the hose coming off the compressor - I was Googling around to figure out where the hose went and potential areas that could leak, but I wasn't using the right keywords or something because I came up empty, thus here I am.
    Any suggestions/help would be greatly appreciated, thanks!
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: AC Issues
    GXP Level Member
    Mar 2015
    Tomball
    Deal with the blend door problem first, then we can deal with the AC. Turn on the Vent and cycle through hot to cold and see what happens.
  3. #3 Re: AC Issues
    Jun 2015
    I'm going to try to write what I found out in the most readable way possible, lol.
    I ran the fan through each speed and with 1 I had pretty much no air, then with each subsequent higher setting it increased until 5 - which blew like crazy. Now, while doing this I noticed that the far left, far right, and lefter-most of the middle three vents are barley pushing any air though, even on 5 they were hardly doing anything. But switching on Recirculate causes the semi-dead three upper vents to start to come to life and put out more air (increases with increased fan speed), not as much as the middle two, but definitely more.
    The heat on the floor with the climate control off is very minimal now - maybe it's dependent on weather, when it was in the 80s and hot out when the bottom vent air was a lot warmer and more noticeable - it's been in the shop on and off for the past week and it's only in the 60s in there. But doing vent or AC in slow fan increases with each increase of fan speed the heat increases a little from the bottom vents, and if the vent or AC is on top and bottom I get the most heat off the bottom, but with it just on upper vents it puts out less heat on the bottom vents.
    Also, I tested out the heat and it's quite...., unimpressive. Not sure if that relates to anything.
  4. #4 Re: AC Issues
    Jun 2015
    Anybody got any ideas/suggestions? Just a place to start and try to fix one problem at a time would be great.
  5. #5 Re: AC Issues
    Jun 2015
    Clearwater, FL
    When your brother recharged your a/c, did he add in any leak detector dye? If he didnt, its still a good idea to add it in. Some refrigerants have it built in. Also, do you have the digital climate control or the sliding control type?
  6. #6 Re: AC Issues
    Jun 2015
    Double Post - Mod Please Delete.
  7. #7 Re: AC Issues
    Jun 2015
    Quote Originally Posted by Dancing Bear View Post
    No, okay - I'll have him charge it with leak detector dye next time he's back.
  8. #8 Re: AC Issues
    Oct 2015
    Chesapeake, VA
    Just wondering if you resolved this issue. My 98 is having the same problems. I have nice cold air blowing on the passenger side, but the air in the drivers side is not as cold. It seems to be about the same volume of air through all the vents though, so I don't believe it to be the blend door.
  9. #9 Re: AC Issues
    could be a blend door actuator. mine took a crap. you can take it off and turn the knob by hand to see if it blows colder or not.
    if it still blows warmer the ac needs to be charged.
  10. #10 Re: AC Issues
    Jun 2015
    Quote Originally Posted by crownvicguy311 View Post
    I took it to a shop and the hvac door actuator and mode module had to be replaced for mine. It was something like $380 worth of parts.
  1. Key Fob Issues
    By i3abydoll in forum General Grand Prix Discussion
    Last Post: 05-07-2015, 11:14 PM
  2. ABS Issues
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2012, 01:58 PM
  3. new guy with some issues
    By 85burbanator in forum Introductions/Noob Questions
    Last Post: 07-16-2010, 07:21 PM
  4. Car issues
    By Gardenmom in forum Introductions/Noob Questions
    Last Post: 06-28-2010, 04:33 PM
  5. issues
    By gtp boy 123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 09:15 AM
