Thread: 06 Grand Prix GXP - Service Stability System - Reduced Engine Power - P0606 C0240
Results 1 to 4 of 4
  1. #1 06 Grand Prix GXP - Service Stability System - Reduced Engine Power - P0606 C0240
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Hi All,
    I'm having a bit of a problem with my 06 GXP. Randomly, upon startup, i got the Service Stability System / Reduce engine power message on the DIC. When the message is up the car drives like a dog. I replaced both front wheel bearings (both had a ton of play) but it did not fix the problem. I get 2 codes on the scanner (see below) but nothing too helpful. Anyone have suggestions? More info is below.
    -Only happens on start up. Never while I'm driving.
    -It is completely random.
    -I get codes P0606 Internal Processor Fault. C0240 PCM Traction Control Not allowed.
    -The airbag light flashes 4 times after startup.
    -The check engine light is on sometimes, sometimes not. It is on sometimes when the power is reduced, sometimes not.
    -The vehicle has 75K miles on it.
    -The scanner shows the speed sensors appear to be working (and match each others speed). I did notice they say 2 mph when I'm standing still.
    2006 Grand Prix GXP
  2. #2 Re: 06 Grand Prix GXP - Service Stability System - Reduced Engine Power - P0606 C0240
    Sounds like the PCM has a internal issue with the P0606 code.
  3. #3 Re: 06 Grand Prix GXP - Service Stability System - Reduced Engine Power - P0606 C0240
    Jul 2008
    New York
    Are you thinking a new PCM would be in order, or that this one would need a re-flash or software update?
    I know the GM dealer wants $80 to just scan into the car. Not 100% sure what my next step should be. If i get a new (used) PCM, isn't there someone on here who could set it up for me? I remember someone used to do the tuning, but i can't remember who.
    2006 Grand Prix GXP
  4. #4 Re: 06 Grand Prix GXP - Service Stability System - Reduced Engine Power - P0606 C0240
    Jul 2008
    New York
    In case anyone stumbles across this, i purchased a used (re-flashed) PCM on eBay. It costs $200 and i did not have to send the core back. It fixed the problem 100%
    Important: You will have to do a re-learn of the security system. It is extremely easy but takes a lot of waiting (about 30 minutes). ALSO you may have to do a crankcase re-learn. I'm not sure but i did it anyway. It can be done by anyone with a more advanced scanning tool.
    2006 Grand Prix GXP
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Replies: 25
    Last Post: 01-26-2013, 11:52 PM
  4. Replies: 14
    Last Post: 09-29-2012, 06:45 AM
  5. Reduced Engine Power/Service Traction Control
    By SteveNMe in forum General Tech Discussion
    Last Post: 08-07-2010, 10:36 AM
