Thread: Ignition Issue? Turn Key = Nothing
Results 1 to 14 of 14
  1. #1 Ignition Issue? Turn Key = Nothing
    Jul 2015
    USA
    Got a 07 GP GT and when I went to start it I got nothing, no click, no turn over, no nothing but all the accessory worked. Almost as if the battery was completely dead but again everything else worked. Tried it a couple times with the key and remote start with no luck so I had my wife get me the other set of keys. It worked the second try with those keys and worked fine until yesterday when it did it again. Took a couple try's to get it started. Once it turns over it fires right up. Any idea what would cause this intermittent problem? Ive had this car a whole 4 days lol
  2. #2 Re: Ignition Issue? Turn Key = Nothing
    GXP Level Member
    Mar 2015
    Tomball
    Is it an aftermarket remote start, and did you get new keys made for it?
    JEff
  3. #3 Re: Ignition Issue? Turn Key = Nothing
    Jul 2015
    USA
    Factory keys and latter on both keys worked. As for the remote, no idea
  4. #4 Re: Ignition Issue? Turn Key = Nothing
    GXP Level Member
    Mar 2015
    Tomball
    Remote start? Does it look like a factory GM remote with a button at the top above the lock and unlock?
  5. #5 Re: Ignition Issue? Turn Key = Nothing
    Jul 2015
    USA
    I'll have to check, I'm assuming they'll say GM if factory?
  6. #6 Re: Ignition Issue? Turn Key = Nothing
    GXP Level Member
    Mar 2015
    Tomball
    The remote not the key, the keys could be from anybody and they would work if properly programmed to the car. but if you have an aftermarket alarm there may be a key hiding under the harness that is causing problems with coding keys. I assume you just bought the car and have no history on it.
    Also the Drivers information center (DIC) will display "Starting Disabled due to Theft System" if it's a key program fault.
    Jeff
  7. #7 Re: Ignition Issue? Turn Key = Nothing
    Jul 2015
    USA
    Ya just got it Friday.
  8. #8 Re: Ignition Issue? Turn Key = Nothing
    dirty tb could cause that,
    or a crank sensor if its been stalling on you while driving and if the tach drops to zero for no reason as well.
    wait edit: no crank at all? try beating the starter with a hammer, see if it will crank then. if still no crank put a test light to the small stud with a wire on the starter solenoid, then have some one turn the key to start, the test light should light up key to crank. if it dont you have power issue to the starter, relay ignition switch, something of that sort.
    you can also try to jump the starter with a screwdriver, it should crank. if it dont somethings up ground cable or pos cable, or the starter is dead locked up.
  9. #9 Re: Ignition Issue? Turn Key = Nothing
    Jul 2015
    USA
    Thanks, hopefully its just the starter solenoid not engaging the starter and I don't have to spend a lot of time troubleshooting it with my DMM. Maybe Ill clean the contacts on the relay for good measure. Its a real intermittent problem now but bound to fail hard at the worst time possible lol
  10. #10 Re: Ignition Issue? Turn Key = Nothing
    GXP Level Member
    Mar 2015
    Tomball
    On your car it's really easy to get to just jack it up (jackstand) enough to reach in there and it's right behind the front tube and if your as lucky as me everything is clean and easy access.
    Jeff
  11. #11 Re: Ignition Issue? Turn Key = Nothing
    when the starter is bad on these newer cars you will hear a click from the dash when the key is turned and it fails to crank. you dont hear it from the starter any more.
  12. #12 Re: Ignition Issue? Turn Key = Nothing
    GXP Level Member
    Mar 2015
    Tomball
    Right unless it's hydro locked, then you hear a click form the starter. lol
    Jeff
  13. #13 Re: Ignition Issue? Turn Key = Nothing
    you know it lol
  14. #14 Re: Ignition Issue? Turn Key = Nothing
    Jul 2015
    USA
    Just left the dealer. He said it sounds like the ignition switch sensor. The bad part is once you restart the car twice it clear the code so he didn't see it. He said if happens again and I get it started to bring it right in before it clears.
    It's under a 50/50 warrenty but once it happened the day I bought it they'd cover it 100%
  1. Replaced ignition and now key & wheel will not turn.
    By elizabeth in forum General Tech Discussion
    Last Post: 09-10-2012, 06:25 AM
  2. 1998 GTP Won't Turn Over, Car Dies, Key stuck in ignition
    By Columbia in forum General Tech Discussion
    Last Post: 08-14-2012, 01:12 PM
  3. Ignition key, won't turn to off position
    By buck in forum General Tech Discussion
    Last Post: 01-11-2012, 12:29 PM
  4. Ignition will not turn to start position
    By glovey in forum General Tech Discussion
    Last Post: 08-08-2011, 03:51 PM
  5. HELP! Ignition key will not turn in 1994 SE
    By cerdman in forum General Tech Discussion
    Last Post: 08-10-2009, 12:09 AM
