Thread: Overheating that doesn't make sense? GT 3.8
Results 1 to 10 of 10
  1. #1 Re: Overheating that doesn't make sense? GT 3.8
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I'm wondering if you filled it properly. When I do my coolant, after flushing and all that crap, first I fill the LIM as far as I can, then install the tstat and put the housing on. I then fill as much as I can in the radiator, and start the car up. I let it run a while, tstat opens, bleed air, coolant goes down, and I keep topping off until it won't take any more. Put the rad cap back on, make sure the reservoir is at the proper level, and done.
    You did let the car run and get up to temp, then top it off before calling it good, right? Don't go by the reservoir, you check the coolant level by removing the rad cap (not hot, obviously).
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  2. #2 Re: Overheating that doesn't make sense? GT 3.8
    GT Level Member Pokealong1227's Avatar
    Oct 2012
    Oak Grove, MO
    Quote Originally Posted by 99GT2dr View Post
    I filled it properly. Like I said before, it ran perfectly for a week and then suddenly started overheating. It was the typical coolant elbows. They were fine with a broken water pump, but with the new pump increasing pressure it cracked both the elbows on the corners of them. Seem to be sealed fine, but cracked pretty bad. Going to replace them with the metal ones this week and it should be fixed.
  1. Why doesn't zzp make stb bracketa anymore?
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 06-22-2015, 05:53 AM
  2. Doesn't make any sense...wtf?!
    By XtrmGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2012, 06:15 AM
  3. Car lurching, tech said maybe throttle switch, does this make sense?
    By tcman49 in forum General Tech Discussion
    Last Post: 08-02-2011, 07:19 AM
  4. Does ANYBODY know how to make sense when they type?
    By MizzBecca in forum The Rant Forum
    Last Post: 08-04-2009, 04:46 PM
  5. Does it make sense to rebuild it before it breaks?
    By Burbman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 04:39 PM
