Thread: I got codes P0455 and P0449
Results 1 to 8 of 8
  1. #1 I got codes P0455 and P0449
    Jan 2012
    Austin,tx
    I replaced the gas cap and reset it and the codes came back. Looks like they have to do with evap system and I have no clue where to start looking. thanks
    06 Grand Prix GT stock, 02 Mustang GT far from stock
  2. #2 Re: I got codes P0455 and P0449
    Would you please list the descriptions for the codes
  3. #3 Re: I got codes P0455 and P0449
    Jan 2012
    Austin,tx
    Sure P0449 Evap purge/vent solenoid circuit condition, the solenoids and system wiring are monitored for opens or shorts. P0455 Evap large leak detected.
  4. #4 Re: I got codes P0455 and P0449
    you got a cracked line or the purge solenoid on the canister tank under the gas door is leaking.
  5. #5 Re: I got codes P0455 and P0449
    Jan 2012
    Austin,tx
    Quote Originally Posted by ScottyDoggs View Post
    Just wanted to say it was the purge solenoid, I got one from rockauto for $20 and put it in and no more check engine light. thanks for your help.
  6. #6 Re: I got codes P0455 and P0449
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    I have had the exact same problem and codes for a while now, making my A/F ratio 15.6-16.2 at idle. Its annoying, kills gas mileage, makes the car smell like you dumped gas in the driveway when you start it up. I assume it is the line running from the purge valve to the motor but havent decided how to tackle it yet. Maybe smoke the line?
    Have replaced both the purge valve and solenoid. Same problem, -21% Fuel trims. Yay.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  7. #7 Re: I got codes P0455 and P0449
    smoke test is the way to go.
  8. #8 Re: I got codes P0455 and P0449
    Thank you for following up. Many times the fix ends up happening w/o any info back.
    Scott.. you know my answer would have been...turn off code and keep on truckin!
  1. OEM #- P0455 help !! 05 GXP
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 01-02-2016, 12:14 PM
  2. P0449 Code (Yep, again)
    By ThaUnknownOne in forum 5.3L V8 (LS4)
    Last Post: 09-30-2013, 07:29 AM
  3. P0449 is back again!
    By gagt3100 in forum General Tech Discussion
    Last Post: 04-13-2013, 01:47 AM
  4. Updated: P0455 - EGR Self-Delete?
    By SlowNA06 in forum General Tech Discussion
    Last Post: 12-14-2010, 12:49 PM
  5. P0449
    By probuilder1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2009, 06:27 PM
