Thread: Obd2 plug wiring
Results 1 to 6 of 6
  1. #1 Obd2 plug wiring
    Dec 2013
    laporte mn
    So I'm looking for the obd2 plug in wiring. I'm wondering where every wire comes from and where the exact location of the plugs/pins are on both ends.
    My aeroforce randomly stopped staying on about a week and a half ago. I have it installed with a add a circuit tapped to the radio fuse and I made sure my power is good. I'm wondering if the gauge itself grounds out through the obd2 plug. Also just recently when I'm scanning using uvscan3 it will freeze which it never did before. There will be blank data for about 3 seconds before the freeze. The system and never froze before, that is why I'm wondering if it's the obd2 plug because both things I plug into it stopped functioning properly at the same time
  2. #2 Re: Obd2 plug wiring
    Apr 2015
    Columbus, OH
    Check the CIG lighter fuse.
    Top Swapped 01 Imp
  3. #3 Re: Obd2 plug wiring
    Dec 2013
    laporte mn
    I will do that
  4. #4 Re: Obd2 plug wiring
    Dec 2013
    laporte mn
    Both cigarette lighters work fine
  5. #5 Re: Obd2 plug wiring
    Apr 2015
    Columbus, OH
    Sorry that's all I got I know in some cars they are connected. Maybe double check the rest of your fuses.
    Top Swapped 01 Imp
  6. #6 Re: Obd2 plug wiring
    Dec 2013
    laporte mn
    I have checked every fuse on the inside and outside under the hood. I'm guessing it is a ground issue at the obd2 plug. But I can't find a schematic that lists G203
  1. Which OBD2 Reader???
    By 02GPinNY in forum General Tech Discussion
    Last Post: 10-07-2012, 07:10 PM
  2. Unknown wiring harness plug
    By Phyrstorm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2011, 06:35 PM
  3. OBD2
    By str3etgl0w in forum General Tech Discussion
    Last Post: 07-19-2011, 02:08 PM
  4. OBD2 codes
    By sra_chipmunk in forum Forum Bugs/Suggestions
    Last Post: 01-14-2008, 12:56 AM
