Hey guys, so my car recently started leaking ATF pretty badly. Seems to be leaking from below the radiator slightly toward the passenger side. After pulling the splash guard off and taking a quick look, I'm 99% sure it's from one or both of the lines that run from the transmission along the crossmember the radiator sits on (when looking up from under the car). One of them seems VERY rusty, although it was hard to see so I couldn't pinpoint exactly where the leak was. I assume these are the trans cooler lines?
Anyway, I was wondering if anyone has any experience with replacing these and can give me an idea of what it would take. I'm hoping it's not too much of a PITA and doesn't require removing the radiator or anything like that. Looking on rockauto under transmission, they list 2 "oil cooler" lines, one upper and lower. Are these them? Are there other parts I need when doing this, like replacement fittings? They have quite a few options listed under oil cooler line connectors, so I'm not too sure what a full set consists of.
Thanks for any help, car is the 02 gtp in my sig btw
