Thread: ATF leak? Trans cooler lines?
Results 1 to 20 of 23
  1. #1 ATF leak? Trans cooler lines?
    GT Level Member yzboy85's Avatar
    Dec 2013
    maine
    Hey guys, so my car recently started leaking ATF pretty badly. Seems to be leaking from below the radiator slightly toward the passenger side. After pulling the splash guard off and taking a quick look, I'm 99% sure it's from one or both of the lines that run from the transmission along the crossmember the radiator sits on (when looking up from under the car). One of them seems VERY rusty, although it was hard to see so I couldn't pinpoint exactly where the leak was. I assume these are the trans cooler lines?
    Anyway, I was wondering if anyone has any experience with replacing these and can give me an idea of what it would take. I'm hoping it's not too much of a PITA and doesn't require removing the radiator or anything like that. Looking on rockauto under transmission, they list 2 "oil cooler" lines, one upper and lower. Are these them? Are there other parts I need when doing this, like replacement fittings? They have quite a few options listed under oil cooler line connectors, so I'm not too sure what a full set consists of.
    Thanks for any help, car is the 02 gtp in my sig btw
    02 GTP Coupe - Jennifer
    SD headers, SLP Powerflo catback, 3.4, CAI, Shift Kit, GMPP Sway Bars, F-Body Brakes
  2. #2 Re: ATF leak? Trans cooler lines?
    they rust break leak where the rubber line meets the metal line.
    line swap is easy, theres a tool. but most dont have it to remove the lines from the rad and tranny. its like a fuel line quick dis connect.
    if you dont have this tool you can pull the wire clip out with a pick, then put the clip right back in the rad or tranny with the line removed.
    when you put the new line in, you just push it in through the clip and you'll feel it click, then tug back on it to make sure its locked in.
  3. #3 Re: ATF leak? Trans cooler lines?
    Mar 2014
    Tucson
    Just one word of warning. Be really careful if you're pulling those clips with a pick. They like to go flying, never to be seen again. I like to have a strong magnet touching the clip as I pull it.
  4. #4 Re: ATF leak? Trans cooler lines?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I recommend replacing both line at the same time and buying extra clips. I used couple tiny screw drivers made it pretty easy to get thrm out. Hsrd part is getting the lines to line back up.
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: ATF leak? Trans cooler lines?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Yes!!!!!
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  6. #6 Re: ATF leak? Trans cooler lines?
    GT Level Member K Slice's Avatar
    Jul 2013
    Traverse City MI
    Just did this job a month or so ago, wasn't any problem. As long as you have spare clips the quick connects actually make the job really easy. I did have to cut the lower line in half to get it out though.
  7. #7 Re: ATF leak? Trans cooler lines?
    Somebody needs to post some part #s
    04 Comp G.
  8. #8 Re: ATF leak? Trans cooler lines?
    Jul 2013
    Traverse City MI
    ACDELCO Part # 10330106 upper
    ACDELCO Part # 10330105 lower
  9. #9 Re: ATF leak? Trans cooler lines?
    theres other how to's. this is dirtdogs got his gxp, trannys the same so it should work for us v6 guys. http://www.grandprixforums.net/threa...r-your-LS4-car
  10. #10 Re: ATF leak? Trans cooler lines?
    Quote Originally Posted by K Slice View Post
    Perfect thanks
    Noted since I'll be doing a cooler soon might as well replace the lines while I'm at it
    04 Comp G.
  11. #11 Re: ATF leak? Trans cooler lines?
    Keep in mind Red that the different years and even sometimes mid year minor changes could change the part number.
  12. #12 Re: ATF leak? Trans cooler lines?
    I'll keep that in mind and I'll double check later on when I get around a computer.
    04 Comp G.
  13. #13 Re: ATF leak? Trans cooler lines?
    How do you rust up lines in florida?
  14. #14 Re: ATF leak? Trans cooler lines?
    You don't lol. Unless it's a northern car.
    04 Comp G.
  15. #15 Re: ATF leak? Trans cooler lines?
    Apr 2012
    Dayton, OH
    I go over with some salt water and sandpaper every other week
    2012 F150 STX
  16. #16 Re: ATF leak? Trans cooler lines?
    Dec 2013
    maine
    do the clips have a specific name so I can pick up some spares at napa?
  17. #17 Re: ATF leak? Trans cooler lines?
    Apr 2012
    Dayton, OH
    I walked into autozone and asked for "jesus clips" I **** you not and they knew exactly what i was talking about lol. This was the box i got has like 2 or 3 different sizes.
    2012 F150 STX
  18. #18 Re: ATF leak? Trans cooler lines?
    if you use a pick, it can really fly. idk how these guys lost the clips.
  19. #19 Re: ATF leak? Trans cooler lines?
    Enfield, CT
  20. #20 Re: ATF leak? Trans cooler lines?
    Dec 2013
    maine
    Got them changed out today, leak seems to have stopped. I'm an idiot and didn't pay attention to how they were routed with all the other ac lines and wire loom and stuff down there...so I'm pretty sure they are in there wrong but oh well, it works.
  1. Need trans cooler lines ...
    By Le Patriote in forum General Grand Prix Discussion
    Last Post: 02-28-2015, 07:21 AM
  2. Trans cooler lines are leaking
    By gpse2000 in forum General Grand Prix Discussion
    Last Post: 07-06-2012, 06:31 AM
  3. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
  4. Tranny lines for trans cooler
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2010, 04:09 PM
  5. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
