Thread: 2 codes
Results 21 to 40 of 44
  1. #21 Re: 2 codes
    http://www.jegs.com/p/Magnaflow/Magn...67828/10002/-1 if you get one thats ca approved, it should be a real cat. not seeing the 3 inch listed in this link tho. thats also known as a carb compliant cat.
  2. #22 Re: 2 codes
    MINNESOTA
    Thanks
    I will keep looking
  3. #23 Re: 2 codes
    MINNESOTA
    Is there a way to check for exhaust leaks
    Can I spray something on them to see where its leaking
  4. #24 Re: 2 codes
    if you hear a leak its leaking. best to let it cool off, aka cold start and then quickly feel around the headers and pipes for a air coming out.
    or you can seafoam it. but if you hear it, you'll feel it for free.
  5. #25 Re: 2 codes
    MINNESOTA
    Can I seafoam a supercharger
    If so how
    I have read a few threads on how to do it, some say to do it by the SC
    Is that correct
  6. #26 Re: 2 codes
    either the brake booster or take a vac line hooked to the nipple under the snout ans let it suck it in via the vac line.
  7. #27 Re: 2 codes
    MINNESOTA
    Thanks
  8. #28 Re: 2 codes
    MINNESOTA
    I just got done with seafoaming the car and I can see couple of leaks one on the front header and others on the band clamps
    I just left the seafoam sit for about 2 minutes, is that not long enough
  9. #29 Re: 2 codes
    The bottle says 15 minutes dont it?
  10. #30 Re: 2 codes
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    2 minutes is defeating the purpose. you're not giving it enough time to soak in and break up the carbon. like scotty said , give it 15 minutes.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  11. #31 Re: 2 codes
    MINNESOTA
    F**k
    Can I do it again or should I do it again
  12. #32 Re: 2 codes
    Dec 2014
    Maryland
    sure...just do a third of the can and throw the rest in your gas tank. make sure you add it slowly
  13. #33 Re: 2 codes
    MINNESOTA
    Ok, thanks
  14. #34 Re: 2 codes
    MINNESOTA
    I dont need one with the 02 hole in it do I
    Like this one
  15. #35 Re: 2 codes
    Didn't read through all the thread, but your location is listed as Minnesota, and I don't remember Minnesota have any emissions testing if it does then just stop reading. Do this and you can save yourself a ton of money and your car will never know the difference. http://www.355nation.net/forum/how-p...ight-pics.html
  16. #36 Re: 2 codes
    MINNESOTA
    Nice, the problem with doing it this way is that I am going to have to hit the firewall more
    But if it works then I will try and do it this way
    No emissions in Minnesota, thank god
    We did have them thou
    20 something years ago
  17. #37 Re: 2 codes
    What does the firewall have to do with anything? The rear O2 is under the car like a foot or two away from the firewall.
    Pretty much right where the one is in this pic.
  18. #38 Re: 2 codes
    that o2 sim goes in the rear o2 so it fools the pcm to not set the po420 code. aka post cat.
    no emissions, get a high flow cat off ebay for like 50 shipped and do the sim trick.
  19. #39 Re: 2 codes
    Why do you keep telling him to get a cat? He does not and probably never will need one.
  20. #40 Re: 2 codes
    MINNESOTA
    Quote Originally Posted by Slick2500 View Post
    I see, so its the one closest to the resonator that its throwing the code
  1. 04 gtp with two codes need help
    By justin10morrissey in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2013, 09:13 PM
  2. 4 Codes - PCM?
    By noreasonwhyy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-10-2013, 09:45 AM
  3. got some codes need help
    By buschegt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2012, 06:20 AM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. PID Codes?
    By BwolfGT in forum Off Topic Discussion
    Last Post: 10-20-2010, 07:41 PM
