Thread: A/C/Heat air blows ONLY from defrost vents and floor
Results 1 to 20 of 37
  1. #1 Re: A/C/Heat air blows ONLY from defrost vents and floor
    some cars dont have that vac ball. the vac line off the sc runs right into the cab of the car.
    if you have a T under the fuse box, you have that ball for sure.
  2. #2 Re: A/C/Heat air blows ONLY from defrost vents and floor
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    You say you tested the vac line coming in. Did it have vacuum?
    If no.. then here's the pic of that res, it's the black ball
    Yeah, do have vacuum. Went under the dash while the car was running. Pulled that line off and it's sucking..lol
    Could that box that line plugs into be bad?
    Quote Originally Posted by bandook View Post
    Drivers side. Was on my car, imagine its the same on yours. There's a bracket it clips in to. Mine popped out of the bracket and wouldn't move the door. Just clipped it back on, fine since.
    Need to check that next. Is that up under the dash?
    Quote Originally Posted by ScottyBDoggs View Post
    I really don't think I have one, I never noticed it when I did my I/C install..
    There is a rubber fitting that connects the two hard plastic lines. One end is the one that comes off the blower, then other is was seem to go down the fender wall by the battery into a wire loom with a bunch of wires that go into the firewall. Which is the same plastic line I disconnected under the dash.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. Air Conditioning blows through vents and then to floor.
    By 74NovaCustom in forum General Tech Discussion
    Last Post: 08-26-2019, 09:08 PM
  2. mode switch will not change from face, feet defrost. blows thru all constant
    By 98GTPPACE in forum Introductions/Noob Questions
    Last Post: 08-10-2013, 03:08 PM
  3. Replies: 0
    Last Post: 08-10-2013, 02:58 PM
  4. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  5. cant control where heat blows to
    By sheffy in forum General Tech Discussion
    Last Post: 01-03-2011, 08:17 PM
