Thread: A/C/Heat air blows ONLY from defrost vents and floor
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: A/C/Heat air blows ONLY from defrost vents and floor
    ive seen the diagram for the part. why the dash comes out, its at the top of the hvac box, just under the dashboard.
  2. #22 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Apr 2015
    Columbus, OH
    Are you talking about that round diaphragm actuator thingy? You have to be a 90lb double jointed circus acrobat to get to it, but its not impossible. Haven't replaced one but I did have to work on mine where it popped loose.
    Top Swapped 01 Imp
  3. #23 Re: A/C/Heat air blows ONLY from defrost vents and floor
    no, its a plastic rod with a flap on it and a plastic arm off it the linkage hooks to. it breaks at the top of the linkage. off this rod.
  4. #24 Re: A/C/Heat air blows ONLY from defrost vents and floor
    We fixed Gregs w/o pulling the car into a billion pieces.
  5. #25 Re: A/C/Heat air blows ONLY from defrost vents and floor
    May 2015
    Wichita, KS
    FWIW I had a very similar problem not too long ago. The air blew out all of the vents and was therefore very very weak. And obviously the vent selector did not work. I needed up replacing the little rubber connector in the picture and now there's a blizzard in my car. Just in time for summer.
  6. #26 Re: A/C/Heat air blows ONLY from defrost vents and floor
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Quote Originally Posted by bandook View Post
    Quote Originally Posted by ScottyDoggs View Post
    I think it is the round diaphragm thing and the plastic rod goes up and down into it and I can't see what the other end of the rod goes to but after looking at that picture again. The top the rod looks like it broke of something.
    and yeah it looks like I need to be a god damn contortionist to fix the damn thing. At least on the drivers side.
    Going to dig into more this weekend.
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  7. #27 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Houston/Baton Rouge
    Wonder if this would help find any other problems.
    You must have a CJ2 unit (pictured below) to view this information. To enter diagnostics mode:
    Press and hold both the Driver and Passenger knobs in simultaneously until the display changes to read "-00". To change position, turn the Driver knob to the desired number and turn the Passenger knob one click to view the data for that position.
    Position Description US Observed on mine Canada
    -00 Error codes (List of Trouble Codes Below!)
    -01 (servo position) 103-107 43-162
    -02 (servo position) 128 120-202
    -03 (servo position) 150 162-194
    -04 CJ2 Fan Speed Low=15, 29, 44, 58, 71, 86, 110=High, CJ2 Unit will adjust to other increments as needed
    -05 (servo position) 93 88-191
    -06 (servo position) -152 00-252
    -07 (servo position) 00 0, 34-255
    -08 (servo position) -155 00-255
    -09 (servo position) 00 0, 23-255
    -10 ? 04 04
    -11 CJ2 Vent Mode 1=Def, 2=Bilevel, 3=Auto, 4=Lower, 5=Def+Lower
    -12 Engine Coolant Temp -60 degrees 80=104, 95=131, 100=140 Peak@135F
    -13 Actual Vehicle Speed in MPH
    -14 (servo position) 00 21=0
    -15 ? 39 44
    -16 Radiator low fan turn on temp -106 207
    -17 Radiator low fan turn off temp 196 199
    -18 ? 50 51
    -19 (servo position) 162-169 40-172
    -20 Affected by cabin temp sensor 89 50-172
    -21 (servo position) 00 ?
    -22 Sunload Sensor -117 LIGHT=126, 218=DARK
    To return to normal operation, press the MODE button next to the Passenger temperature knob.
    This is a list of the Trouble Codes displayed by the CJ2 Unit.
    A two digit code indicates a current fault while a three digit code indicates a historic fault.
    Trouble Code Description
    00 No System Fault
    01 or 101 Inside Air Temperature Sensor Short
    02 or 102 Inside Air Temperature Sensor Open
    03 or 103 Ambient Outside Temperature Sensor Short
    04 or 104 Ambient Outside Temperature Sensor Open
    05 or 105 LH Electric Actuator Open or Short
    06 or 106 RH Electric Actuator Open or Short
    07 or 107 UART Serial Data Line Fault
    08 or 108 Solar Sensor Open
    To clear codes from the CJ2 Unit, press the A/C Mode button.
  8. #28 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Houston/Baton Rouge
    Well, find the problem.
    This little fukcer has caused me problems for over 10 years.
    It was very fun to get out, just hope I could get the new one in. Was going to superglue it but would be pissed if it broke again..
    Thanks again Scotty for all the help..
  9. #29 Re: A/C/Heat air blows ONLY from defrost vents and floor
    your lucky it broke low like that. what side is that from?
  10. #30 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Houston/Baton Rouge
    Drivers side
    How do they normally break?
    Passenger side looks fine, but I didn't check to see if it moves. Doing that today.
  11. #31 Re: A/C/Heat air blows ONLY from defrost vents and floor
    the plastic breaks most of the time. that looks like a metal rod.
  12. #32 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Houston/Baton Rouge
    Yeah, everything seems to function fine. Just metal arm broke.. Have no idea how that could happen..
    I've been under my dash many times, but never messed around with these Actuators. Hell I didn't even know they were there.. lol
  13. #33 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Houston/Baton Rouge
    YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
    It works!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
    But holy **** that thing was a ***** to get back on that little hook!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    After fighting with it for over 3 hours with breaks in between. I realized the hole on the metal arm is very small on this new part compared to the longer oblong hole on the stock part. So in order for me to get the new part on. I would have raise it almost horizontal and slide it on the hook.
    Ummmmmmm, that's not going to happen. There is no room. lol
    Even making the hole big enough was still hard to get on the hook.
    I got a coat hanger and made a hook, so I could wrap it around the other hook. Pulled it down so I could slide the metal arm on to it. Trust me it took way more than a few trys to get it.
    ohh, Then I turn my car on to test it. Climate Control doesn't come on!!!!! !!! I was literal about to drive it off a bridge..lol
    Come to find out I took of a ground wire when I un-installed that lower metal piece. I have no idea why that ground wire way over by the headlight switch has something to do with the Climate Control but it does. So it came on.!!!!!!!!!!! All good.
    Now just need to get my A/C vacuumed and recharged and will be ready to go..
    I can't tell you how excited I am. This has been 10+ years with no A/C and almost as long with this air flow problem.!!!!!!!!!!!!!!!!!!!!
    Thanks Thanks Thanks again Scotty and Bill and anybody else for the help.
  14. #34 Re: A/C/Heat air blows ONLY from defrost vents and floor
    i didnt think those things were such a pita to change. that part sucks, but now you'll get cold air in the face when the a/c gets repaired.
    10 years is a long time for no a/c. some how the a/c is one of the very few things ive not had to mess with in my car. its blown ice cold since the day i got it. if it was to fail, it would be high on the list of repairs asap!!!!
  15. #35 Re: A/C/Heat air blows ONLY from defrost vents and floor
    SE Level Member zbban1's Avatar
    May 2014
    Mi
    I couldn't have said it any better than that...period. LOL
    Just went through this myself, although I did have a/c, it didn't blow out of the vents it was supposed to and blew from the defroster, weak, blah. With Scotty's help, now it'll blow you out of the car in a couple of mins. on max! Fixed cruise, too, which hasn't been working since i bought the car. Now I'm so used to not having it, it's hard to remember when I get out on the highway that I can actually set it and CRUISE! lol
  16. #36 Re: A/C/Heat air blows ONLY from defrost vents and floor
    Houston/Baton Rouge
    Luckily the GTP has been a garage queen for a while now. I agree if it was my daily, the ac would have been fixed a long time ago.
    Quote Originally Posted by zbban1 View Post
    That's good to hear, I've seen some of your post too!!!
  17. #37 Re: A/C/Heat air blows ONLY from defrost vents and floor
    May 2014
    Mi
    Thanks! Mine was a matter of vacuum lines being jimmy-rigged and blocked off by the previous owner. I just hope I never have to replace the part you did, sounds like it was a PITA...
    Now get that a/c charged back up and enjoy!!! I know I am...lol.
  1. Air Conditioning blows through vents and then to floor.
    By 74NovaCustom in forum General Tech Discussion
    Last Post: 08-26-2019, 09:08 PM
  2. mode switch will not change from face, feet defrost. blows thru all constant
    By 98GTPPACE in forum Introductions/Noob Questions
    Last Post: 08-10-2013, 03:08 PM
  3. Replies: 0
    Last Post: 08-10-2013, 02:58 PM
  4. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  5. cant control where heat blows to
    By sheffy in forum General Tech Discussion
    Last Post: 01-03-2011, 08:17 PM
