Thread: a/c not blowing where it should????
Results 1 to 5 of 5
  1. #1 a/c not blowing where it should????
    Jan 2015
    illinois
    does the actuator control the blenderbox on a 99 gtp. or is it vacumn controlled or both?/?
  2. #2 Re: a/c not blowing where it should????
    theres a vac line off the pass side fore wall, it goes to the top of the blower ot the back of a na manifold, it powers the air flow direction.
    check to see if its broken or fallen off.
  3. #3 Re: a/c not blowing where it should????
    Jan 2015
    illinois
    does this matter it will change to defrost if i push the defrost button on dash
    "not the mode switch which changes other settings" i can tell it moves the dampers but it doesnt shut the damper to the floor
  4. #4 Re: a/c not blowing where it should????
    follow this how to to open up the dash. the round parts in the diagram move the air flow they are vac pwered. car running, move the air flow and watch the rods on both sides for movement.
    http://www.grandprixforums.net/threa...or-Replacement
  5. #5 Re: a/c not blowing where it should????
    Jan 2015
    illinois
    thanks for the info a lot to get into really appreciate the help
    thanks
  1. A/c blowing hot air
    By mikey666 in forum General Tech Discussion
    Last Post: 05-10-2013, 05:27 AM
  2. 99 blowing cold air
    By anarchy in forum General Tech Discussion
    Last Post: 12-27-2012, 01:53 PM
  3. AC not blowing air
    By Aopps in forum General Tech Discussion
    Last Post: 06-14-2012, 10:00 PM
  4. blowing air,,but not hot
    By mimi in forum General Tech Discussion
    Last Post: 12-14-2010, 02:40 AM
  5. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
