Thread: Front end clunk 03 GTP
Results 1 to 14 of 14
  1. #1 Front end clunk 03 GTP
    GT Level Member jake91's Avatar
    Jun 2012
    mesa az
    Any ideas what this clunk is. Recently replace control arms, swaybars including poly bushings and endlinks, installed ssc springs, and tie rod ends. This happens every initial acceleration from a stop, going over speed bumps and sometimes while turning over uneven surfaces.
    It sounds like someone is hitting the subframe with a hammer and its loudest on the pass side
    Ive checked the endlinks, torque on all the bolts, and the calipers are tight
    Only visible issue i can see is the cv axle is spewing grease
    Sorry the vid is sideways
    https://youtu.be/aHWkSLcMNlU
    2003 Pontiac Grand Prix GTP, thrasher intake, intense poly upper mounts, 06+ Impala dual piston calipers, 88k miles
  2. #2 Re: Front end clunk 03 GTP
    Massachusetts
    Wow, that's a good one alright. Let me what you find when you get it resolved.
  3. #3 Re: Front end clunk 03 GTP
    Aug 2013
    Lisle
    Change that CV axle!! The car I just bought had a bad drivers side CV axle. The boot was ripped to shreds and it was dry as a bone as in no grease. It made a terrible popping noise when I would make turns or at take off. Plus it would be a good time to check further in the suspension like the cradle mounts since mine need to be changed which can get oil soaked to make them deteriorate cause of the oil.
  4. #4 Re: Front end clunk 03 GTP
    St. Louis
    CV axle is the obvious one here. If the grease is gone, then the CV is likely shot. Get a Napa axle and call it a day. Might also want to give all the cradle mounts a lookover as well as mentioned.
  5. #5 Re: Front end clunk 03 GTP
    Jun 2012
    mesa az
    Well took a look over the car today either the axle or endlinks most likely
    https://youtu.be/LDI-_S_w-ao
  6. #6 Re: Front end clunk 03 GTP
    Apr 2015
    Columbus, OH
    Yeah, axle shouldn't sound like that. Looks pretty sloppy where it goes into the tranny. Your Diff might be shot. Dunno. End links are definitely loose. Should set it on the ground and tighten end links. The Moogs I just put in were like 20ft/lbs or less. Put some threadlocker on the bolt.
    Top Swapped 01 Imp
  7. #7 Front end clunk 03 GTP
    Jun 2012
    mesa az
    Oh didnt think about tightening the end link while on the ground that makes since. Eeek hope its not the diff, and just the axle
  8. #8 Re: Front end clunk 03 GTP
    Enfield, CT
    I always just jack up the control arm up carefully to simulate the same angle as it would be on the ground and then tighten the links
    Sent from my LG G3
  9. #9 Re: Front end clunk 03 GTP
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    Same here.
  10. #10 Re: Front end clunk 03 GTP
    Jun 2012
    mesa az
    Went to try and tighten up the endlinks more today and stripped them out. So i installed some new GMPP ones i had laying around. Seems to have quited the clunk a bit but its still there all the time, but just attribute this to the fact they are rubber and the old endlinks were poly. Next step will be the axle
  11. #11 Re: Front end clunk 03 GTP
    Jun 2012
    mesa az
    Forgot to update it was a busted motor mount
    Sent from my iPad using Tapatalk
  12. #12 Re: Front end clunk 03 GTP
    Apr 2015
    Columbus, OH
    Awesome! Thanks for updating, its always nice to see a help me thread wrapped up with a conclusion.
    Top Swapped 01 Imp
  13. #13 Re: Front end clunk 03 GTP
    Massachusetts
    Quote Originally Posted by bandook View Post
    Roger that. Thanks for the update. It is nice to see the solution to your vexing problem so that if any of us ever experience the same thing we will know what to look for.
  14. #14 Re: Front end clunk 03 GTP
    Banned
    My clunk was from sub frame bushings fyi
  1. front end clunk.
    By 13aceofspades13 in forum General Tech Discussion
    Last Post: 07-03-2014, 05:03 PM
  2. Front end clunk/click.
    By silvermistgt2002 in forum General Tech Discussion
    Last Post: 06-20-2014, 10:51 AM
  3. Front End Clunk
    By jcgre3n in forum General Tech Discussion
    Last Post: 03-29-2012, 05:41 PM
  4. 01' GTP Front End Clunk
    By Comanche1959 in forum Brakes/Suspension/Chassis
    Last Post: 02-27-2012, 01:55 PM
  5. Front-End Clunk
    By xerxescct in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2010, 02:25 PM
