Thread: ZZP Snout machining tool. How to use it. Yes i searched
Results 1 to 14 of 14
  1. #1 ZZP Snout machining tool. How to use it. Yes i searched
    GT Level Member Hardonyomom's Avatar
    aurora
    Can anybody tell me how to use the snout machining tool or point me in the right direction? It did not come with instructions and the video link on zzp's website is not working anymore. thanks
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  2. #2 Re: ZZP Snout machining tool. How to use it. Yes i searched
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    I can't help you but did you try emailing ZZP? They've always had a good response time when I've contacted them.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  3. #3 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Buffalo
    Crank that **** with a drill
  4. #4 Re: ZZP Snout machining tool. How to use it. Yes i searched
    GTP Level Member
    Pittsburgh
    if its like the intense tool.
    Install the pulley and mark on the snout where the end of the pulley is
    remove the pulley and install the machine tool
    use a drill and machine the snout
    this is the Intense machine shout tool
    2003 SSEi,
  5. #5 Re: ZZP Snout machining tool. How to use it. Yes i searched
    hangover park IL
    dont over tension the spring, slower cutting is better and leaves a finish you wouldnt mind see'n.
    mark the pulley overhang on the snout. zzp stick in further than the intense. easier to cut to a line on a iece of masking tape than to continually test fitment and R&R tool
    ~James~ Psychotic Gearhead
  6. #6 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Buffalo
    Just did this recently as well. There was some confusion - of course - by me when I asked how can you measure the pulley over hang on the snout if you have to remove your MPS hub? The thread said you had to remove the MPS hub in order to use the tool. Well that's fine if you had a hub on there - you could measure and then remove it.
    Mine was already removed. So I didn't want to install it. Then remove it. Then reinstall it.
    Well the the tool I received from Marshal was made to fit over the MPS hub. So it was a breeze to use. I installed the hub, I used my zzp 3.0 as its wider then the intense 2.8 I have as well. Made the cut. Looks great.
  7. #7 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Bob, the tool you used is the same one in Pat's picture. Meaning...the actual one that he used... It's like that
  8. #8 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Buffalo
    Right. I'm clarifying the fact that people were saying you can't use it with the MPS installed. When in fact you can
  9. #9 Re: ZZP Snout machining tool. How to use it. Yes i searched
    I could have told ya that.
    You take off the pulley.. slap that baby on and spin the heck out of it. stop..slightly tighten nut.. go again.. repeat until done or covered in metal shavings.
  10. #10 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Buffalo
    Yeah well someone said the MPS hub had to be off. In case anyone else read the same thread it's bullcrap lmao!
  11. #11 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Kemmerer, Wyoming
    I'm having a hell of a time getting this tool to bite, in this video it looks like he is going counter clockwise, am I right?
    https://www.youtube.com/watch?v=9PqSlwtOOKg
  12. #12 Re: ZZP Snout machining tool. How to use it. Yes i searched
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    The vid that plays after your linked one shows it being done clockwise, by hand, with socket and extension. You should be able to tell which way it needs to go by feeling up inside it with your finger. One way will feel sharp, I imagine..
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  13. #13 Re: ZZP Snout machining tool. How to use it. Yes i searched
    May 2016
    Rouge Island
  14. #14 Re: ZZP Snout machining tool. How to use it. Yes i searched
    Kemmerer, Wyoming
    the bolt wouldn't tighten down on the hub and the round part of the tool, it took me a while to figure out what was wrong, but I figured it out now, I think. I gave up for the night, and will start again tomorrow after work. I did notice that if you do spin it slow it looks shiny.
    I used 2 lock washers to get the tool to bite, one on each side of the round thing.
  1. Help with Rod Replacement... yes I searched.
    By nukkinfuttz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2015, 12:55 PM
  2. WTB snout machine tool
    By pontiac4lifesc in forum Wanted To Buy - Parts
    Last Post: 01-26-2014, 02:37 PM
  3. Machining Supercharger Snout?
    By transam24 in forum General Tech Discussion
    Last Post: 11-19-2013, 06:33 AM
  4. CAI-Already searched the forums
    By Bkindhart in forum 04+ Specifics
    Last Post: 04-24-2013, 09:13 PM
