Thread: basic radiator fan ??
Results 1 to 16 of 16
  1. #1 basic radiator fan ??
    Jan 2015
    illinois
    my daughter has a 04 grand prix gt recently had radiator changed leaking at end caps i think now the fans dont come on could have been prior problem just the info im gettin .fans will come on when the a/c is on .one more thing that may be related the a/c doesnt blow cold but this maybe a different problem i dont know if compressor kicks in or not main ? is what relay would this be caused by or?what should i check next?
  2. #2 Re: basic radiator fan ??
    Feb 2013
    37.295091, -121.930053
    well if the fan is turning on then its ok. theres nothing for you to do
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: basic radiator fan ??
    pop the hood turn the ac on, see if the compressor turns or not.
    fans dont come on till 212 degrees too, so its got to be all warmed up.
  4. #4 Re: basic radiator fan ??
    Jan 2015
    illinois
    so i dont have the car here but is 212 less than 3/4 on the temp gauge also does one of the relays have anything to do w/ the a/c clutch engagement?
  5. #5 Re: basic radiator fan ??
    maybe, but if its low on r- what ever we use now it wont blow cold as the clutch wont spin.
    it could also be the blend door actuators are not turning and its stuck on hot. but see if the compressor clutch is spinning first.
  6. #6 Re: basic radiator fan ??
    Feb 2013
    your ac system maybe low on freon. if its low it wont blow cold or barely blow cold. so get a cheapo gauge and run the ac and you will see if its in the green
  7. #7 Re: basic radiator fan ??
    Jan 2015
    illinois
    the a/c is not the main issue. the radiator fans dont come on unless you turn on the a/c .not blowing cold is not what i m askimg about but what relay or fan control switch do i need to check cause the fans work but not until you turn on the a/c??
  8. #8 Re: basic radiator fan ??
    ok so its over heating?
    then it could be the temp sensor under the t stat in the lim. if you unplug it both fans should come on and stay on.
  9. #9 Re: basic radiator fan ??
    Jan 2015
    illinois
    hey thanks for the info i will post again when i can check it out!!!!
  10. #10 Re: basic radiator fan ??
    best to get a delco sensor. most guys who swap it for a aftermarket sensor change it 3 times due to new in the box bad sensors.
  11. #11 Re: basic radiator fan ??
    GXP Level Member
    Mar 2015
    Tomball
    On the newer cars like the 05' the fans don't come on until 220.
    Jeff
  12. #12 Re: basic radiator fan ??
    thats the high speed fan setting. 220 ish. 212 they should turn on. cant trust the dash gauge, its never really correct.
  13. #13 Re: basic radiator fan ??
    just looked at a 05 bin, its 212 and hi speed is @ 219. same as the rest of em really.
  14. #14 Re: basic radiator fan ??
    GXP Level Member
    Mar 2015
    Tomball
    Then I guess I'm not getting low speed on either. Better go check some relays. The high speed fans are the same speed as when the AC is on.
    Jeff
  15. #15 Re: basic radiator fan ??
    you must be running hot as hell like that. id check the relays, swap em around.
  16. #16 Re: basic radiator fan ??
    GXP Level Member
    Mar 2015
    Tomball
    Not really, since I put in the 180* thermostat it doesn't get over 195. It will get as high as 221 then will drop to 205 or so. If I'm running th AC it will stay about 195-206 in stopped traffic if I'm rolling its 195 but if it's a cool day it will be about 188. With the 195 it would stay about 205 in traffic and about 195 at a cruise. In traffic now it will raise to 221 then drop down to 205 without the AC running.
    My relays function out of circuit. I'm not real sure how this works because there are 3 relays labeled 1,2,3 so you have 2 fans. I would guess that the smaller relay using a resistor I haven't found could do low speed then 2&3 come on for high speed. I haven't looked at that part of the schem yet though.
    Jeff
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. Basic Mod Question
    By KIRALY in forum General Tech Discussion
    Last Post: 09-06-2012, 04:19 PM
  3. Basic ?? 3.4
    By brian91z34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2012, 08:25 AM
  4. Basic Mod Preference
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 06:41 PM
  5. Basic audio Qs
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2008, 12:27 PM
