Thread: O2 extension for headers
Results 1 to 12 of 12
  1. #1 O2 extension for headers
    Sep 2014
    Lexington, MI
    Just ordered some SD headers and was wondering if the ZZP O2 extension is any good or if people have had any issues with it. Any input is appreciated.
    2000 GTP ZZP pcm, drilled/slotted rotors, homemade intake
  2. #2 Re: O2 extension for headers
    Dec 2013
    ohio
    No issues at all. Plug in and go.
  3. #3 Re: O2 extension for headers
    May 2012
    Where winter never ends
    Ran one for the last 75K miles, never an issue. Actually forgot it was there since I technically dont need it anymore lol.
    2000 Regal - Winter Beater
  4. #4 Re: O2 extension for headers
    Sep 2014
    Lexington, MI
    Sounds good, that's all I needed to hear. Now for the fun install of the headers lol.
  5. #5 Re: O2 extension for headers
    May 2012
    easy job
  6. #6 Re: O2 extension for headers
    GT Level Member Xorbex's Avatar
    Canada
    don't use the sd exhaust manifold gaskets. mine blew out almost immediately causing a nasty leak and tick. Re-use the old stock or order oems
    forgot to mention the zzp extension works great for me and it looks clean also
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  7. #7 Re: O2 extension for headers
    Sep 2014
    Lexington, MI
    Let's hope so! Lol
  8. #8 Re: O2 extension for headers
    Sep 2014
    Lexington, MI
    That's what I heard. Also, are the U clamps really that bad or should I not worry about them.
  9. #9 Re: O2 extension for headers
    Canada
    you need 4 stepped band clamps. even with those im coming close to leaks. 2 x 2.5" and 2x 3"
  10. #10 Re: O2 extension for headers
    you can cut the o2 plug off the cars harness, then add 3 feet of wire to it to make the plug extended. this way you can run the o2 harness way out of the way of the rear header.
  11. #11 Re: O2 extension for headers
    Antioch, IL
    ran SD gaskets AND clamps for over 3 years not a single problem, you guys are just weak
    2009 Challenger SRT8
    Expert at being gay.
  12. #12 Re: O2 extension for headers
    Sep 2014
    Lexington, MI
    I also noticed in Bills how-to he mentioned the egr. Should I just get rid of it and block it off, or leave it hooked up
  1. WANTED ..SE lower lip extension for the front bumper or INFERNO lip extension
    By egyptiansuperman in forum Wanted To Buy - Parts
    Last Post: 09-12-2014, 05:52 PM
  2. Do i need an O2 extension wiht speed daddy headers?
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2013, 02:25 PM
  3. Making O2 sensor extension for headers - which wire goes where?
    By Elite6 in forum General Tech Discussion
    Last Post: 09-07-2012, 11:17 AM
  4. o2 extension
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 07-22-2010, 12:13 AM
