Ok, so in my latest go-round with this car (05' GTP) we figured the knock sensor(s) were bad so I decided to pull them
both and change them. I have also had an issue where the pcm commands the bypass open and I drop boost to 0. Recently I have gotten P0068 which throws the car into Reduced power and that's freaking dangerous. In watching the sensors MAP, Baro, and MAF they seem to be in line but the 1900+ cfm at 6-7psi throws me off. So I went to G/sec.
ive been through all the vacuum lines with a fine tooth comb and am in the process of replacing all the plastic tubing with 3/16" steel line.
tonight I had readings of 267g/sec/ -2* timing and 1.6psi also dead rich on the O2 set as graph. Now the reason I am not using KR in this is because it simply won't work. If it works then nothing else does I've tried everything and nothing has helped. Not real sure what's going on just yet but if I can log the other items then I should be able to tell Kr.
So this brings me to tonight I got the car up on ramps and removed both the knock sensor wires and connected them to the new knock sensors wrapped in basically bubble wrap. It was cut up pieces of Mylar bubble sunshade. I Ty wrapped them in nice little bundles and tied them to the firmly to brackets and such that they cannot move and are dampend as much as you would expect. I went for a drive and didn't have the bog that usually (sometimes) occours. The timing was about 40* when I eased down the neighborhood, then at the stop in gear it was 15* which has been normal. Then I take off and it is in the 30's and 40's and as I lean on it the pressure spikes above 0 then drops back and timing goes to -2* other readings above.
what the hell is going on? Do I have to reset something?
Thanks,
Jeff
