Thread: Red interior lights not working. help!!!
Results 1 to 11 of 11
  1. #1 Red interior lights not working. help!!!
    Feb 2015
    california
    Red Interior lighting not working no other electrical problems. Dashlights out center console lights out and the side panel button lights all not working. Did a fuse blow? I've been checking fuses. Help!
  2. #2 Re: Red interior lights not working. help!!!
    I'd say it's either a fuse...or all the bulbs burned out at once, which is very unlikely.
    Were there any odd things that happened before this occurred?
  3. #3 Re: Red interior lights not working. help!!!
    Feb 2013
    37.295091, -121.930053
    yeah he tried to do something to his car......
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: Red interior lights not working. help!!!
    Feb 2015
    california
    Nothing unusual. I highly doubt they all went out at once. I was using a volt booster from zzp disconnected and still nothing
  5. #5 Re: Red interior lights not working. help!!!
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by silenthaven View Post
    I was using a volt booster from zzp.....
    Remove that POS. I had one for a few months and it cooked my battery.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Red interior lights not working. help!!!
    Feb 2015
    california
    Quote Originally Posted by Bronco Boy View Post
    removed but didnt fix the problem. is there a bad fuse?
  7. #7 Re: Red interior lights not working. help!!!
    Jul 2010
    Coquitlam,BC,Canada
    Of course not. Those things create more problems than they are worth. Removing it just prevented future problems.
    Check the dome light fuse. Next step would be to check for power; at the headlight switch, at the fuse etc. You have described that parts of two different circuits are faulty, so you will need to do some testing.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Red interior lights not working. help!!!
    Uhmm.. having used a Caspers voltage booster at one time and knowing ZZP quality issues. How bright did those babies get before they stopped working?
    Caspers was designed to give 17volts and WOW the increase in headlights and interior lights. I feared for the electronics in the car and got that outta there fast.
  9. #9 Re: Red interior lights not working. help!!!
    Feb 2015
    california
    Damn it was fairly brighter. Maybe dimmer switch?
  10. #10 Re: Red interior lights not working. help!!!
    Yoga city
    anything above 14.9 is unsafe for a battery and above that say goodbye to electronics. Not designed for the heat that is generated. POP!
  11. #11 Re: Red interior lights not working. help!!!
    Feb 2015
    california
    Headlights work fine, the switch for parking and headlights work fine. Its the lights that work off dimmer switch that don't work...
  1. Radio and interior lights stopped working
    By Thompsju in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2013, 04:43 PM
  2. interior lights/exterior lights newbie question
    By spider4 in forum General Tech Discussion
    Last Post: 11-10-2011, 08:34 PM
  3. Interior lights not working
    By jmanrta in forum General Tech Discussion
    Last Post: 11-30-2010, 12:37 PM
  4. power windows, locks, moonroof, interior lights not working!! HELP!
    By rottenhippo in forum General Tech Discussion
    Last Post: 10-30-2010, 02:19 PM
  5. need help! interior lights and trunk light not working
    By nemesis in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2010, 09:01 PM
