Tonight I went to replace the front sidemarker bulb on my 04 gp and when I put the bulb in no luck but when I would hit the connector my low beams would shut off so the 2 ends that connector together that the low beams,high beams,side marker lights are running on looked at both ends and the one with the pins 2 are broken and melted inside the other connector so I need to get both connectors now where would I get them ??? and are they expensive
