Thread: Thinking of buying a spare. motor to build
Results 1 to 20 of 57
  1. #1 Re: Thinking of buying a spare. motor to build
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    Was going to freshen it up with new bearings and such but Ouse the Pistons,rods and crank alone
  2. #2 Re: Thinking of buying a spare. motor to build
    Quote Originally Posted by Lil larry View Post
    JUST NO! like said earlier, dont touch the bottom end. or you'll just waste it. thats called a 200 mile engine.
    your also gonna want a way to tune it when done. it should run on a gtp stock pcm, but a tune will help it out.
  3. #3 Re: Thinking of buying a spare. motor to build
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by ADecker View Post
    I have heads and and ST5 in my basement, along with a double roller. Head studs on the way then the 600+ wHP fun begins.
    Question: What the hell? Why do people have issues building a short block? I don't understand. I have built everything from Briggs and Stratton and other small engines, 2 cylinder 2 stroke Rotax, Lycoming I/O 360, LS1's, several Chevy 350/383'sQuad 4, Ford 3.8 SC, 3.1/3.4's and never had any issues with an engine coming apart. Not to say everything has gone perfectly, but come on a 3.8 Buick? What's the deal? Not trying to be a smart ass or anything just seems really odd that messing with a bottom end would be a 200 mile engine unless you do like my dad did on a VW engine and torqued the mains and rods without using a torque wrench and seized the engine after about 5 miles that was in the early 70's when he was becoming an aircraft mechanic in the Army and thought it's just a car engine it doesn't need to be held to the standards that aircraft do.
    Jeff
  4. #4 Re: Thinking of buying a spare. motor to build
    St. Louis
    Quote Originally Posted by J57ltr View Post
    Jeff
    Because on these motors, once you take the main caps off and pull the crank the block twists. You need to line bore the block to be sure it is straight before you reassemble everything or it won't last. I'm sure there are some other things that need to be done but this one is for sure. Can't be done like your average smallblock chevy.
  5. #5 Re: Thinking of buying a spare. motor to build
    Jeff
    give it a shot, let us all know how long it lasts. lol its the only block under the sun you've not re built too.
    one guy popped in here, him and his dad were doing a rebuild, we told him not to. his dad said they dont know jack lol and they rebuilt it and we never heard back from him, ( thinking cause it blew up soon after) and we told ya so lol
  1. Thinking about buying a gtp.
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 10:46 AM
  2. Thinking of buying a 06' gxp
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 12-27-2009, 09:26 PM
  3. thinking about buying a 98 with a bad motor
    By allensteiner21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 09:21 AM
  4. Thinking about buying 07 or 08 GP
    By sn95gt50 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2009, 08:08 PM
