Thread: Thinking of buying a spare. motor to build
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
  1. #1 Thinking of buying a spare. motor to build
    SE Level Member Lil larry's Avatar
    Nov 2012
    Elkview, west virginia
    Can I still use a na motor and can I use the stock bottom end or should I go a different route
  2. #2 Re: Thinking of buying a spare. motor to build
    Yes you can use a n/a bottom end, the compression ratio is going to be higher though. And DO NOT touch the bottom end.
  3. #3 Re: Thinking of buying a spare. motor to build
    its what im doing, got a n/a engine on the stand, 200 bucks in new gaskets and other odds and ends for it, picked up spare heads to port/ clean up.
  4. #4 Re: Thinking of buying a spare. motor to build
    Nov 2012
    Was going to freshen it up with new bearings and such but Ouse the Pistons,rods and crank alone
  5. #5 Re: Thinking of buying a spare. motor to build
    You probably don't want do that.. Very seldom do guys have goodluck when they start messing with the bottom end.. Just get a good n/a motor.. And leave the bottom end alone.. There's a reason the big HP Turbo guys still run stock bottom ends..
    04 Comp G.
  6. #6 Re: Thinking of buying a spare. motor to build
    Quote Originally Posted by Lil larry View Post
    JUST NO! like said earlier, dont touch the bottom end. or you'll just waste it. thats called a 200 mile engine.
    your also gonna want a way to tune it when done. it should run on a gtp stock pcm, but a tune will help it out.
  7. #7 Re: Thinking of buying a spare. motor to build
    Nov 2012
    Thnks
  8. #8 Re: Thinking of buying a spare. motor to build
    Buffalo
  9. #9 Re: Thinking of buying a spare. motor to build
    Someone told me that ZZPs world record car uses a stock l36 bottom end.
  10. #10 Re: Thinking of buying a spare. motor to build
    May 2008
    Schuyler, NE
    It was an l67 bottom end.
  11. #11 Re: Thinking of buying a spare. motor to build
    Nov 2012
    Would it be easier to just buy a new short block then I can't find a low miles one round where I live
  12. #12 Re: Thinking of buying a spare. motor to build
    last i saw a rebuilt crate block was over a grand, for a short block, long blocks go up to 2 grand easy.
    last guy here who did all the right things to rebuild his engine, machine shop costs and parts was also over 2 grand. why a used engine is the choice most of us make.
  13. #13 Re: Thinking of buying a spare. motor to build
    Buffalo
    I Know where you can get a motor under 10 miles shipped to your door. But gotta have money ready
  14. #14 Thinking of buying a spare. motor to build
    then you spend $150-200 and regasket everything and you have cheap new to you motor
    04 Comp G.
  15. #15 Re: Thinking of buying a spare. motor to build
    im up to 220 in gaskets with fluids filters elbows valve seals and head bolts. not to bad really.
  16. #16 Re: Thinking of buying a spare. motor to build
    May 2012
    Where winter never ends
    Stock Bottom end, 25 PSI Turbo build, XP Cam.... Stay stock bottom end.
    2000 Regal - Winter Beater
  17. #17 Re: Thinking of buying a spare. motor to build
    Mar 2012
    NC
    Quote Originally Posted by ADecker View Post
    Stock Bottom end, very ported heads, big cam, 25 PSI Turbo build, head studs.... Stay stock bottom end.
    Fixed.
  18. #18 Re: Thinking of buying a spare. motor to build
    May 2012
    Stock head bolts right now Ticking time bomb
    Big cam and heads are not in...yet
  19. #19 Re: Thinking of buying a spare. motor to build
    Mar 2012
    NC
    Get to making some money and do it right.
  20. #20 Re: Thinking of buying a spare. motor to build
    May 2012
    I have heads and and ST5 in my basement, along with a double roller. Head studs on the way then the 600+ wHP fun begins.
  1. Thinking about buying a gtp.
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 10:46 AM
  2. Thinking of buying a 06' gxp
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 12-27-2009, 09:26 PM
  3. thinking about buying a 98 with a bad motor
    By allensteiner21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-15-2009, 09:21 AM
  4. Thinking about buying 07 or 08 GP
    By sn95gt50 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2009, 08:08 PM
