Thread: How to run compression check (safely) when partly disassembled?
Results 1 to 3 of 3
  1. #1 How to run compression check (safely) when partly disassembled?
    Mar 2015
    Connecticut
    Since I've got my LIM off (and everything it took to get to it) to replace/clean a bunch of stuff, I'd like to make sure my head gaskets are OK. Got a few questions about running a compression check in this state, so that if they're leaking I don't have to break it down again.
    Fuel relay already out and system depressurized, so no problem there.
    Coil packs off and disconnected. Will that, or any other disconnected electronics, cause the ECU to prevent cranking? (Obviously I don't want spark, but I don't know if the ECU needs to see any particular circuitry to allow cranking)
    Good idea to reattach dogbones before cranking? Could the engine rotate and cause damage without them?
    Haven't drained oil yet, so still should have lubrication.
    Any other things that need to be ON or OFF to do this?
  2. #2 Re: How to run compression check (safely) when partly disassembled?
    Personally if it ran semi decent when you pulled it apart, I'd skip the head gasket/compression check. These motors are super reliable and hardly ever have a HG issue.
  3. #3 Re: How to run compression check (safely) when partly disassembled?
    Mar 2015
    Connecticut
    OK, thanks. Besides, I forgot the engine should ideally be warm for the compression test.
  1. Boosting High Compression vs Low Compression M90 Setup
    By Impala131 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2014, 07:08 PM
  2. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  3. compression check
    By justwhisen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2009, 10:09 PM
  4. Compression Check?
    By 99prixgt in forum General Tech Discussion
    Last Post: 06-09-2009, 11:01 AM
  5. Can this be safely fixed?????
    By YoungGTP in forum Visual/Body Modifications
    Last Post: 11-10-2008, 11:24 AM
