Thread: Where is this water coming from?
Results 1 to 8 of 8
  1. #1 Where is this water coming from?
    Nov 2010
    Baltimore
    When I park my car facing up hill it'll leak water on the passenger side floor not much, but enough to be a pita. When I park it facing down hill i'll hardly see a drop. What the hell's going on here? It's not coming in through the door dripping down by speaker area. I've heard of that problem. Believe me I've got the door sealed up tight. On top of that one time I had some under my rear seat cushing that I have yet to figure out how it got there. Also it's not coming from up front because when I pull up the carpet you can feel what areas wet and what isn't. It's coming from the right side somewhere, but it's not the door.
  2. #2 Re: Where is this water coming from?
    http://www.grandprixforums.net/threa...-Permanent-Fix
    Check that
    04 Comp G.
  3. #3 Re: Where is this water coming from?
    yup ^^^^^
  4. #4 Re: Where is this water coming from?
    Nov 2010
    Baltimore
    That's not the problem. I already have that part. I've had it for 5 or 6 years now. It's not leaking from up front. It's on the side somewhere. It's hard to diagnose it using a water hose because a hose just doesn't show it the way rain does. Rain water is steady and over several hours. Where you'll get a slow drip.
  5. #5 Re: Where is this water coming from?
    GXP Level Member
    Mar 2015
    Tomball
    Do you have a sunroof?
  6. #6 Re: Where is this water coming from?
    Nov 2010
    Baltimore
    Yes, but I pulled down part of the headliner on and the drainage connections looked fine. Unless it's leaking pass them somewhere.
  7. #7 Re: Where is this water coming from?
    Jul 2010
    Coquitlam,BC,Canada
    Get the hose back on it and start looking.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Where is this water coming from?
    GXP Level Member
    Mar 2015
    Tomball
    Usually the hoses will get debris in them and it will back up and leak inside the car. Never seen it on a GP but on tons of other cars when I used to install them. Use compressed air to blow them out.
    Jeff
  1. Bad water pump,wrong water pump? 2002 GTP
    By R STARR in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 06:47 AM
  2. Do you run distilled water or water out of the tap in your cars?
    By Slick2500 in forum Off Topic Discussion
    Last Post: 10-14-2012, 10:59 AM
  3. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. Key not coming out
    By Bruteforce72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 04:19 PM
