Thread: electrical squeal thats constant/never changes
Results 1 to 17 of 17
  1. #1 electrical squeal thats constant/never changes
    Aug 2008
    Louisville
    I have a very high pitched electrical squeal that occurs at all times, from engine start to engine off. It never changes pitch or volume under any circumstances. I cant seem to track it down as it seems like i can hear it from the engine bay and under the car but cant distinguish which side? As vaugue as this description is, has anyone else run into this?
  2. #2 Re: electrical squeal thats constant/never changes
    GXP Level Member
    Mar 2015
    Tomball
    An electrical squeal? The only squeal I could even think of being close is a tensioner. A mechanics stethoscope comes in very handy in this situation either that or a really long screwdriver or other long rod. Place one end on the bolt of the tensioner and your thumb on the other end then press your thumb knuckle in your ear and listen.
    Jeff
  3. #3 Re: electrical squeal thats constant/never changes
    May 2012
    Where winter never ends
    Did you recently install anything electric? Radio? Gauge? If its coming from your speakers you have a ground loop interference.. whatever you installed needs a ground loop isolator, or ground it somewhere else.
    2000 Regal - Winter Beater
  4. #4 Re: electrical squeal thats constant/never changes
    Buffalo
    Pissed-off fuel pump?
  5. #5 Re: electrical squeal thats constant/never changes
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I can seem to remember an issue similar to this on a 1998 Buick Lesabre. Try making sure all of your accessories are unplugged. I once had a cigarette lighter port that was really corroded and nasty, and if I plugged something into it, I would get a high pitched squeal. Replacing the lighter port fixed the issue.
    Pretty sure the "squeal" noise was coming from the alternator when this happened.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  6. #6 Re: electrical squeal thats constant/never changes
    Jul 2010
    Coquitlam,BC,Canada
    FYI, electricity does not squeal.
    As mentioned, a stethoscope is needed. If you don't have one, take a piece of hose (fuel, air etc) and cut it to 2-3' long; works just the same as a stethoscope.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: electrical squeal thats constant/never changes
    Aug 2008
    Louisville
    Thanks guys. I'll try all of this and get back to you
  8. #8 Re: electrical squeal thats constant/never changes
    Aug 2008
    Louisville
    So taking everyone's advice I took another listen and it seems as though the sound is not coming from under the hood but from the rear of the car. I can hear the noise well from both wheelwells as well as in the trunk. After comments here and in research on the forum, it looks like I might have an angry fuel pump. Now I just need to see what it would take to repair or replace it. The search continues…
  9. #9 Re: electrical squeal thats constant/never changes
    St. Louis
    Since you didn't post what year your GP is and how many miles are on it, I would suggest replacing the fuel filter first if you haven't at some point and see if the pump quiets down. When the filter gets clogged it will make the pump work harder, hence the noise.
  10. #10 Re: electrical squeal thats constant/never changes
    Aug 2008
    Louisville
    Thanks for the heads up. I have an 04 with 124k mi. Fuel filter was replaced at around 100k mi. I'll replace it again as cheap insurance and hope for the best. Great thought.
  11. #11 Re: electrical squeal thats constant/never changes
    May 2012
    Quote Originally Posted by Bronco Boy View Post
    Firstly, it can and does squeal. in fact electricity makes lots of noises. Lightning cracks, High voltages and amperage's hum, feedback loops squeal. A good example of this is install a wideband and ground it near the radio or speakers ground, ill put 20 bucks down you hear a nice high pitch squeel. Ground loop interference is a *****, need a ground loop isolator to take care of the problem, I needed one in my car. Its basically a low pass filter, high frequencies cant pass through it.
    so again I ask, did you install any new electronics or touch anything electronic?
    It very well could also be your fuel pump or alternator dying.
  12. #12 Re: electrical squeal thats constant/never changes
    Jul 2010
    Coquitlam,BC,Canada
    FYI, properly installed electrical components do not squeal.
    Fixed it for you.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: electrical squeal thats constant/never changes
    GTP Level Member buickman104's Avatar
    NYC
    Thanks I was having this issue. I bought a ground loop isolator last night. Will arrive by Friday. Let you know how it works!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  14. #14 Re: electrical squeal thats constant/never changes
    Aug 2008
    Louisville
    Quote Originally Posted by FordMan77 View Post
    You sir, are THE man. Sure enough, a 10 minute filter change solved the problem instantaneously. I wouldn't in a million years have thought about the strain on the pump. Thank you for giving me my sanity back!
  15. #15 Re: electrical squeal thats constant/never changes
    Buffalo
    ^ wait what?
  16. #16 Re: electrical squeal thats constant/never changes
    GXP Level Member
    Mar 2015
    Tomball
    Lol, it was pissed off alright. I wouldn't have guessed that, but I had an S-10 2.8 manual that had a filter so clogged the truck would buck and bark the tires. It was very embarrassing. The filter was so clogged that when I tried to blow into it, it pressurized and when I moved out of the way vapor came out. About 2 weeks later the pump failed.
    Jeff
  17. #17 Re: electrical squeal thats constant/never changes
    Buffalo
    Yah I think I nailed the whining sound on this car when it whined from both ends ......
  1. Constant Electrical Drain Running Down The Battery
    By falcongt in forum General Tech Discussion
    Last Post: 11-06-2017, 07:09 PM
  2. Constant 5v Source Anywhere?
    By 94GrandPrixSE in forum General Tech Discussion
    Last Post: 04-24-2015, 08:04 AM
  3. constant ticking under dash!!!!
    By canadian2000gtp in forum General Grand Prix Discussion
    Last Post: 09-07-2013, 05:09 PM
  4. Need help locating 12v constant and 12v ignition
    By acidcrashdburnd in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2013, 08:46 PM
  5. Damn constant repairs!!!
    By WhiteGT in forum The Rant Forum
    Last Post: 05-23-2009, 05:05 PM
