Thread: Stage 1 Volt Booster - Modified
Results 1 to 20 of 22
  1. #1 Re: Stage 1 Volt Booster - Modified
    Jul 2008
    nj
    I have the big 3 done on my car, I was looking to increase the voltage just a little bit for a better spark and possibly increase the speed of my pumps. Hopefully this helps my idle voltage when I reduce the idle again for the fun sound of my cam. I do wonder if this works well for the after market stereos that have an issue with the stage 2 voltage booster.
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  2. #2 Re: Stage 1 Volt Booster - Modified
    SE Level Member StreetShaker's Avatar
    Feb 2009
    Tyrone, Central PA
    Quote Originally Posted by Damojo2003 View Post
    I have the big 3 done on my car, I was looking to increase the voltage just a little bit for a better spark...
    You will get no better spark. The voltage regulator for the coils only outputs a set amount of voltage. It will store the correct amount, and only emit a certain amount. It will turn away any increase, because, after all, it is regulated.
    So you pretty much wasted your time with that one.
    Proud Member of the Central PA Wrecking Crew
  3. #3 Re: Stage 1 Volt Booster - Modified
    Highland Heights, KY
    I bought the stage 1 a while back. Is this diode safe to do with a Vplus voltage booster and the alternator power cable. Or does this generate to much voltage.
  4. #4 Re: Stage 1 Volt Booster - Modified
    Jul 2008
    nj
    Quote Originally Posted by StreetShaker View Post
    O well, it kept me busy. The real test for me is when it is 100* outside and I am in stop and go traffic with the AC cranking. So far this mod with the big 3 helped my idle voltage alot. Which is the reason for my looking into this.
    FOR SALE
  1. How much octane booster?
    By Sabrewings in forum General Tech Discussion
    Last Post: 08-18-2009, 11:19 PM
  2. Where to hook up oil pressure & volt gauge
    By 98GT3800 in forum General Tech Discussion
    Last Post: 02-14-2009, 10:26 PM
  3. Booster
    By SJ95GTLQ1 in forum Brakes/Suspension/Chassis
    Last Post: 09-17-2008, 10:38 PM
  4. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
  5. Octane booster
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 02:04 PM
