lube the lock up.
if that dont work you can take the back seat out, climb in the trunk and un bolt the lock hardware pop the trunk open, then change the lock tumbler.
the lock actuator is also changeable. once the trunk is open you can test for power when the button is pushed to pop the trunk. if the plug gets power the actuator is bad.
