Thread: starting a top swap on a 2000 gp l36 still collecting parts
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
randybill starting a top swap on a 2000... 09-15-2014, 11:52 PM
SnowTh1ef Re: starting a top swap on a... 09-16-2014, 03:36 PM
SnowTh1ef Re: starting a top swap on a... 09-16-2014, 03:39 PM
randybill Re: starting a top swap on a... 09-17-2014, 08:51 AM
SnowTh1ef Re: starting a top swap on a... 09-17-2014, 09:08 AM
BillBoost37 Re: starting a top swap on a... 09-17-2014, 11:33 AM
randybill Re: starting a top swap on a... 09-23-2014, 01:37 AM
randybill Re: starting a top swap on a... 09-25-2014, 10:11 PM
SnowTh1ef Re: starting a top swap on a... 09-26-2014, 10:18 AM
SnowTh1ef Re: starting a top swap on a... 09-26-2014, 10:19 AM
MCbatt Re: starting a top swap on a... 09-26-2014, 07:00 AM
darkhorizon Re: starting a top swap on a... 09-26-2014, 07:14 AM
randybill Re: starting a top swap on a... 10-03-2014, 01:48 PM
SnowTh1ef Re: starting a top swap on a... 10-03-2014, 02:42 PM
SnowTh1ef Re: starting a top swap on a... 10-03-2014, 02:44 PM
SnowTh1ef Re: starting a top swap on a... 10-03-2014, 02:50 PM
sseilmnop starting a top swap on a 2000... 10-03-2014, 03:30 PM
SnowTh1ef Re: starting a top swap on a... 10-03-2014, 03:30 PM
sseilmnop starting a top swap on a 2000... 10-03-2014, 03:32 PM
SnowTh1ef Re: starting a top swap on a... 10-03-2014, 03:32 PM
randybill Re: starting a top swap on a... 10-11-2014, 11:42 AM
SnowTh1ef Re: starting a top swap on a... 10-11-2014, 11:48 AM
randybill Re: starting a top swap on a... 10-11-2014, 05:07 PM
Frosty Re: starting a top swap on a... 10-15-2014, 10:19 PM
Frosty Re: starting a top swap on a... 10-15-2014, 10:17 PM
randybill Re: starting a top swap on a... 10-16-2014, 09:06 AM
SnowTh1ef Re: starting a top swap on a... 10-16-2014, 09:49 AM
Scottydoggs Re: starting a top swap on a... 10-16-2014, 09:58 AM
randybill Re: starting a top swap on a... 03-03-2015, 10:00 PM
Scottydoggs Re: starting a top swap on a... 03-03-2015, 10:38 PM
Frosty Re: starting a top swap on a... 03-04-2015, 01:39 AM
randybill Re: starting a top swap on a... 03-04-2015, 09:03 AM
Scottydoggs Re: starting a top swap on a... 03-04-2015, 09:13 AM
randybill Re: starting a top swap on a... 03-04-2015, 11:13 AM
Scottydoggs Re: starting a top swap on a... 03-04-2015, 03:25 PM
randybill Re: starting a top swap on a... 03-18-2015, 07:22 PM
Scottydoggs Re: starting a top swap on a... 03-18-2015, 07:24 PM
randybill Re: starting a top swap on a... 03-19-2015, 11:15 AM
Scottydoggs Re: starting a top swap on a... 03-19-2015, 11:55 AM
Impala131 Re: starting a top swap on a... 03-19-2015, 12:21 PM
randybill Re: starting a top swap on a... 03-23-2015, 10:24 PM
GTPpower Re: starting a top swap on a... 03-24-2015, 01:19 PM
randybill Re: starting a top swap on a... 03-24-2015, 02:40 PM
  1. #1 starting a top swap on a 2000 gp l36 still collecting parts
    missouri
    this project started as a intake manifold gasket change out to an l26 intake manifold swap. then at the junkyard looking for a l26 manifold i found a 1999 GTP. that made my decision easy to do a top swap. unfortunately someone before me had taken some parts off the engine before i could get to it!!
    here's l67 stuff i was able to grab from the junkyard:
    *heads
    *valve covers
    *m90 but missing the bolts!
    *boost valve
    *lim w/bolts
    *coil mount and coils
    *map sensor with bracket and vacuum hose from map to "T" on LIM
    *idler standoff with hardware
    *brake booster hose
    *throttle body with all sensors attached
    *digital dic- update 9/20/14- installed the dic and it works great. my car didnt have the connector in the dash so i had to do some splicing....
    UPDATE 9/23/14 have harmonic dampner, both idler pulleys with bolts, tensioner with pulley and unicorn nut and belt. 2002 gtp fuel rail and injectors showed up today too.
    on order-evac purge valve hose
    things i can source/have/can find easily:
    *off the shelf tuned pcm (looking at overkill and intense) anyone with either of these tuned pcms from either of these companies?
    *top swap installation kit from zzp (comes with gaskets, crank bolt, rocker bolts etc)
    *sensor extension kit from zzp
    *put together my own vacuum lines ( found a dorman rubber tee to use on the FPR and gonna use hard emisson line to have a factory looking vacuum line setup.)
    *now i'm looking at some obx headers....
    I'm at a disadvantage on this swap since the car had been pirated before i got to it but i feel i got most of the components. i've been reading for about 5 hours this evening and i feel i've read enough to then ask you guys for some help. so, what other parts do i need besides what i've listed and where can i find them?? thanks in advance!
    update 9/24/14- looks like the only thing i'm lacking are the supercharger bolts themselves. anyone have the sizes of them all or where i can get a "kit"? i have the LIM bolts just not the UIM/supercharger bolts
    Last edited by randybill; 09-24-2014 at 10:43 PM. Reason: more details/new infomation from other posts
  2. #2 Re: starting a top swap on a 2000 gp l36 still collecting parts
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Take a bench grinder to any ol 15 mm nut for your unicorn nut and make the head a 13 mm. Works great.
    Vaccuum hoses just set up your own with line and T's from the parts store.
    Also if you get an l32 map sensor it will just plug into your wiring harness and you don't need to adapt it at all.
    You can use your stock throttle body. l67 isn't much different, but if you got it cheap at a JY then kudos.
    Coils are the same as well.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    This thread has A LOT of info on idler and tensioner pulleys that you might need and other things
    http://www.grandprixforums.net/threa...t=common+parts
  4. #4 Re: starting a top swap on a 2000 gp l36 still collecting parts
    missouri
    SnowTh1ef- thanks for your input! it really helps out on the project.
  5. #5 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    No problem. Just did a topswap on my bonnie last august. So most of this stuff is fresh in my mind. Pop over to my build thread in members rides, might have some other stuff about it as well.
  6. #6 Re: starting a top swap on a 2000 gp l36 still collecting parts
    The pulley bolts should be normal thread. IIRC the only reverse thread is the alternator tensioner. The pulley's are standard pullies that you can find info on in the Common Parts and goops thread. Pretty sure the tensioner pulley is a 2.5" like the stock alt tensioner pulley, the front most one is ribbed and also 2.5", then the idler is 3"
  7. #7 Re: starting a top swap on a 2000 gp l36 still collecting parts
    missouri
    just need to figure out what tuner to use- overkill or intense and what headers to get. i'm leaning toward the stainless obx and leave the factory catback system alone. i've read the crossover tube on the obx headers has to be cut but i can handle that. small price to pay for a cheaper set of stainless headers.
    update 9/24/14 ordered the obx headers.
  8. #8 Re: starting a top swap on a 2000 gp l36 still collecting parts
    missouri
    anyone have part numbers for the supercharger to LIM bolts? or does someone sell a kit? help here please.
  9. #9 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    Quote Originally Posted by randybill View Post
    Not part numbers.. But I found the sizes a while back. Let me dig around.
  10. #10 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    Return the OBX headers, they're garbage, speed daddy's are cheaper and easier to install and are also stainless....
  11. #11 Re: starting a top swap on a 2000 gp l36 still collecting parts
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Did you check any junkyards around you?
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  12. #12 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Feb 2009
    flintnasty MI
    Zzp is the only top swap pcm ive ever seen done correctly.
  13. #13 Re: starting a top swap on a 2000 gp l36 still collecting parts
    missouri
    Any news on the m90 bolt sizes? All the stickied thread said was bolt head size. I need to know length, dia, pitch etc
  14. #14 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    Gen3 L67 supercharger bolts
    M8x1.25x??? (1)
    M8x1.25x??? (1)
    M8x1.25x80 (1)
    M8x1.25x45 (7)
    This is what I could find. on 3800pro.
  15. #15 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    and for a gen v the 2 with ??? are 120 and 140 mm. don't know what size they are for a gen 3
  16. #16 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    try sending a PM to SSEILMNOP he sells IC kits with bolts, so he should have a good idea of what those bolt sizes are. If not just ask him what size bolts his ic kits use and take off 2.25"
  17. #17 starting a top swap on a 2000 gp l36 still collecting parts
    Mercer, Pa
    Gen 3 L67 stock supercharger to LIM.
    1 - M8x1.25x85
    1 - M8x1.25x65
    8 - M8x1.25x45
  18. #18 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    I knew you would know!
  19. #19 starting a top swap on a 2000 gp l36 still collecting parts
    Mercer, Pa
    I found the thread gr8racingfool answers me 3-4 years ago.
  20. #20 Re: starting a top swap on a 2000 gp l36 still collecting parts
    Aug 2013
    Sandy, UT
    ah. gotcha.
  1. Need Starting System Schematic for 2000 GP GTP
    By GPJeff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2015, 10:43 AM
  2. 2000 Grand Prix GT not starting.
    By Grim844 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2012, 03:17 PM
  3. 2000 gtp not starting
    By grhein in forum General Tech Discussion
    Last Post: 07-11-2011, 03:36 PM
  4. 2000 GP SE problems starting and idling
    By the daveman in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-05-2009, 08:40 AM
