Thread: Turn the Key - Everything Shuts Off
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
  1. #1 Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    When I turn the key to try and start my GTP - everything shuts off. Dash lights, stereo, everything. Even when the car is on a jump starter - so it isn't the battery.
    Also, the starter won't turn over at all - except when we jump the solenoid... Then the starter turns over, but the bend spring does not engage.
    Additionally, the headlights flicker when the car is only on battery power - however they are fine when on the booster... Any thoughts on that?
    I know there are a lot of questions, but there are a lot of problems - and I have no idea where to start.
    Thanks in advance
  2. #2 Re: Turn the Key - Everything Shuts Off
    take the battery terminals off and clean them, put them back on jump start if needed.
    check the grounds on the trans bell housing too. make sure they are all tight and clean.
  3. #3 Re: Turn the Key - Everything Shuts Off
    Jan 2014
    AR
    Also check the connection under the jumpstart terminal, where the big red wire made into the positive battery cable connects to the electrical center on the strut tower. If thats loose, all kinds of strange things can happen. The negative cable is real long (on 97-03) so visually inspect all along that as well.
  4. #4 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    Battery and terminals are brand new - will check the tranny ground and report back.
    The other thing is the prior owner did a bunch of electrical work behind the dash, and I'm nowhere how good of a job they did...
  5. #5 Re: Turn the Key - Everything Shuts Off
    when you turn the key everything blacks out? but comes back on when you let the key back to run right?
    try having someone hold the key to start, then hit the starter with a hammer. if it cranks the starters dead. dead starter will also click in the dash when you turn the key.
  6. #6 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    Alright, when I turn the key to on, the DIC, stereo and AC shut off. Dash lights stay on. Also, there is a click from the right side of the dash, sounds like by the DIC.
    And yes, when I turn the key back off everything turns back on.
  7. #7 Re: Turn the Key - Everything Shuts Off
    thats the starter i bet, go hit it with a hammer. if it cranks get a new starter.
  8. #8 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    What exactly does hitting it with a hammer do?
    But I tried it, didn't do anything.
  9. #9 Re: Turn the Key - Everything Shuts Off
    it makes a dead starter work for one time after its hit.
    you got a test light? next test is to have someone hold the key to start, and see if you get power to the little stud on the starter with the wire on it, the one your jumping, if its got power key to start, the solenoid or starter is bad for sure, cause its getting the signal to crank.
  10. #10 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    I don't have a test light... I'll have to get one tomorrow if we can't figure this out by then...
    As for the positive on the strut tower - you mean the one running to the fuse block right?
  11. #11 Re: Turn the Key - Everything Shuts Off
    yes red wire on the top of the fuse box. make sure its tight.
  12. #12 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    Alright. checked that wire, and it is tight.
    Another thought just occurred to me - on my old man's old one ton van, he was having electrical issues, and couldn't figure them out for anything. Turned out to be a fusible link within the electrical system... Are there any fusible links in the Grand Prixs? Mine is a 2000 GTP if it makes any difference.
  13. #13 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    Tranny grounds are good by the way.
  14. #14 Re: Turn the Key - Everything Shuts Off
    you have one, but i think most of the car goes dead full time when it blows. super rare to happen.
    how hard did you hit the starter? some times it takes a few good shots. sometimes all it needs is a tap. you want to hit the fat round body of the starter.
  15. #15 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    I hit it with some decent force, enough to make a few little dents... I'm afraid to hit it too hard, because if the starter is fine, I don't want to break it, lol.
  16. #16 Re: Turn the Key - Everything Shuts Off
    I only hit the starter if someone else is turning the key over.
  17. #17 Re: Turn the Key - Everything Shuts Off
    may be your ignition control module. whack the right side of the steering column near where the key goes into the ignition. the are prone to going bad on these cars.
  18. #18 Re: Turn the Key - Everything Shuts Off
    Donating Users Uno99's Avatar
    Appleton, Wi
    My battery had a gap between the positive battery connection. Even tho it was clean and tight i had to put a steel washer inbetween the battery post then tighten it to male a good connection now im all good
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  19. #19 Re: Turn the Key - Everything Shuts Off
    Apr 2014
    Maplewood
    Had the starter tested, it's fine.
    Checked every ground I could find in the car, and replaced the hot going to the starter - still no luck.
    Haven't tried the ICM, it's a $170 part from Autozone... Don't really want to spend that much with no guarantee of success.
    My next step is probably going to be to check for shorts in the dash itself...
  20. #20 Re: Turn the Key - Everything Shuts Off
    you test for power at the little wire on the starter, key to crank yet? if that wire is dead then you can start looking at the starter relay.
    icm has nothing to do with the car cranking over.
  1. Has anyone modified combination stop/turn/tail lights to independent turn signals?
    By April Thompson in forum Visual/Body Modifications
    Last Post: 03-02-2015, 08:22 PM
  2. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  3. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  4. Replies: 21
    Last Post: 08-30-2010, 07:41 PM
  5. just shuts off
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 12:16 AM
