Thread: Any reason my HVAC fuse should be missing?
Results 1 to 6 of 6
  1. #1 Any reason my HVAC fuse should be missing?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    Been playing around in the interior fuse box trying to solve another issue when I noticed that two fuses are missing; radio amp and HVAC control.
    The radio I assume was removed by the installer when I had my aftermarket system installed. But why would the HVAC be gone?
    Might it be the reason for the warm air in my car and not the blend door actuator as I've been suspecting?
    Thanks people.
    1999 Grand Prix GTP sedan
    Speed Daddy headers, 3.25" on a ZZP MPS, high-flow cat, 180
    ° t-stat, Autolite copper 104s, shift kit, ReptileTune...
  2. #2 Re: Any reason my HVAC fuse should be missing?
    pop a fuse in there.
  3. #3 Re: Any reason my HVAC fuse should be missing?
    Sep 2014
    St. Paul, MN
    I intend to. But I haven't owned the car for long so I'm wondering if there's a common reason it might have been removed.
  4. #4 Re: Any reason my HVAC fuse should be missing?
    who knows, take a chance, pop a new one in there, the worst that can happen is the fuse blows. then you'll have a idea why its not there.
  5. #5 Re: Any reason my HVAC fuse should be missing?
    Mar 2014
    Tucson
    Usually a pulled fuse is someone's idea of "solving" an electrical issue. Can't think of any other reason to leave a fuse out of the panel.
  6. #6 Re: Any reason my HVAC fuse should be missing?
    Jan 2014
    AR
    I can think of one... some of us elder GP lovers can't stand the compressor running in winter. GM set it up to stay off below 37 degrees but for those of us who don't jam out much, the sound can be annoying since its almost as loud as the whole rest of the engine. I let mine run until I think to turn it off with the button because it does help keep the system's lubricant distributed throughout the system and a lot of compressors used to go bad from going dry due to little use in winter.
  1. Missing HVAC CTRL fuse? Damaged? (pic)
    By jasonnovak in forum General Tech Discussion
    Last Post: 01-15-2014, 11:40 AM
  2. Missing HVAC Vacuum Hose??
    By brandonl2000 in forum General Tech Discussion
    Last Post: 01-15-2011, 04:39 PM
  3. Will Dual HVAC Work in Stock HVAC
    By ljmonnin12 in forum General Tech Discussion
    Last Post: 11-25-2010, 10:57 PM
  4. Fuse box missing female plug?
    By Mitchstrp in forum General Tech Discussion
    Last Post: 10-24-2010, 12:45 AM
  5. Missing fuse?
    By 05PontiacGP in forum General Tech Discussion
    Last Post: 10-23-2010, 06:13 PM
