Thread: Throwing code P1811
Results 1 to 5 of 5
  1. #1 Throwing code P1811
    Jul 2012
    Michigan
    Hey guys, looking for some help. I have a 2002 Grand Prix GT. it's currently Throwing code P1811 and I'm just looking for a way to fix it. Is this something that is going to kill my transmission? Ive noticed it happens between 3rd and 4th gear. Car seems to hold around 3000 rpms a little to long and eventually you will feel it shift to correct gear. I've checked Fluid and I'm good there.
    I read on here someone sells a shift kit that fixes this issue. Just looking for someone to point me in the right direction.
  2. #2 Re: Throwing code P1811
    http://tripleedgeperformance.com/Harsh-Shift-P1811.html
    http://shop.tripleedgeperformance.co...it-K84908M.htm
    That is what you want, you can find it on ebay for cheaper sometimes. Note that it might not fix it 100%, but it can surely help.
  3. #3 Re: Throwing code P1811
    Jul 2012
    Michigan
    Thanks, appreciate it.
    So let me ask, is this something that eventually causes transmission failure? or is it just a just a little something that I can deal with? cause I notice after I get that shift into the correct gear, the car seems to drive fine and shift properly until I turn it off.
    I drive mostly highway, 55 miles at a time.
  4. #4 Re: Throwing code P1811
    If you put in the shift kit.. it'll take care of the issue to the point that it won't cause further problems in the trans. Essentially..it's masking the problem by shifting a little faster/firmer than stock.
  5. #5 Re: Throwing code P1811
    Jul 2010
    Coquitlam,BC,Canada
    As mentioned, the shift kit is a "band-aid" solution. With that being said, my band-aid has been holding up for 4 years now (daily driving). I didn't do the trans cooler, and I do run warm in the summer (as highs as 208*), so I would recommend doing that too. Doing this will help the trans live a longer life as to high of line pressure is a trans killer.
    Here is a good thread to read: http://www.grandprixforums.net/threa...Shift-Solution
    Here is my install: http://chrisb.users.superford.org/Gr...Shift_Kit.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. P1811 Code Transmission 91,000 miles
    By hampshire32000 in forum General Tech Discussion
    Last Post: 09-19-2013, 11:31 AM
  2. keep throwing misfire code! HELP!!
    By 98GTPPACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2013, 08:32 AM
  3. p1811 code fixed
    By bigtee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-11-2010, 04:18 PM
  4. throwing a code ive never seen before, helppp!!
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 08:06 PM
  5. p1811 code no fourth, clean oil.
    By boden in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-12-2010, 08:40 PM
