Thread: Throwing code P1811
Results 1 to 5 of 5
  1. #1 Re: Throwing code P1811
    If you put in the shift kit.. it'll take care of the issue to the point that it won't cause further problems in the trans. Essentially..it's masking the problem by shifting a little faster/firmer than stock.
  2. #2 Re: Throwing code P1811
    Jul 2010
    Coquitlam,BC,Canada
    As mentioned, the shift kit is a "band-aid" solution. With that being said, my band-aid has been holding up for 4 years now (daily driving). I didn't do the trans cooler, and I do run warm in the summer (as highs as 208*), so I would recommend doing that too. Doing this will help the trans live a longer life as to high of line pressure is a trans killer.
    Here is a good thread to read: http://www.grandprixforums.net/threa...Shift-Solution
    Here is my install: http://chrisb.users.superford.org/Gr...Shift_Kit.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. P1811 Code Transmission 91,000 miles
    By hampshire32000 in forum General Tech Discussion
    Last Post: 09-19-2013, 11:31 AM
  2. keep throwing misfire code! HELP!!
    By 98GTPPACE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2013, 08:32 AM
  3. p1811 code fixed
    By bigtee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-11-2010, 04:18 PM
  4. throwing a code ive never seen before, helppp!!
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 08:06 PM
  5. p1811 code no fourth, clean oil.
    By boden in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-12-2010, 08:40 PM
