Thread: High Pressure line stuck
Results 1 to 20 of 27
  1. #1 High Pressure line stuck
    Feb 2015
    Monticello, MN
    Im doing the High Pressure power steering line on my 2002 GP GT. Ive hit it with penetrating oil and heat and a bfp. Still wont budge. Anyone got any ideas on how to get er out?
    2002 Grand Prix GT - no mods, probably gonna stay that way
    1997 Chevy K1500 - Flowmaster dual exhaust, 140 amp alt, blue LEDs err where, subs
  2. #2 Re: High Pressure line stuck
    More heat.
    But then it might ruin the hose.
  3. #3 Re: High Pressure line stuck
    use a line wrench, and some thing to add leverage to the wrench.
    what side is stuck? pump or rack side?
  4. #4 Re: High Pressure line stuck
    Feb 2015
    Monticello, MN
    I could care less if i ruin the hose. Im replacing it anyway. I used a line wrench with a bfp. Im gonna see if i can use a lift tomorrow and really get it. Its stuck on the rack side.
  5. #5 Re: High Pressure line stuck
    if you lower the sub frame you'll have a better angle at it. they are tight, once they crack free they come right off.
  6. #6 Re: High Pressure line stuck
    Feb 2015
    Monticello, MN
    Alright. My sub-frame didnt look too bad. So hopefully i can get it up on a lift tomorrow.
  7. #7 Re: High Pressure line stuck
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Just find a good position and put some ass into it, it breaks free eventually, but you gotta contort yourself into the right spot.
  8. #8 Re: High Pressure line stuck
    Feb 2015
    Monticello, MN
    Im gonna buy some PB blaster and MAP gas and try to just heat the living heck out of it. Ill get it eventually. Thanks for all the help guys!
  9. #9 Re: High Pressure line stuck
    id not heat it, you may f up a seal in the rack or something. get some leverage and it will pop free.
  10. #10 Re: High Pressure line stuck
    SWPA
    I'm probably asking the obvious, but are you turning the correct way?
  11. #11 Re: High Pressure line stuck
    Feb 2015
    Monticello, MN
    Lol yes I am. Unless its a left hand thread. Ive had some pretty good leverage on it and nothing. I even tried tightening it a little bit but this thing doesn't move one way or another.
  12. #12 Re: High Pressure line stuck
    SWPA
    From the video Scotty posted the other day about steering rack replacement I would say the threads are normal righty tighty, lefty loosey.
    Just make sure you are pulling down on the wrench when it is coming out the back part of the subframe.
  13. #13 Re: High Pressure line stuck
    are you a real light person? under 150 lbs? lol
    if you haven't stripped the nut or snapped the wrench, you have not tried hard enough.
  14. #14 Re: High Pressure line stuck
    Jan 2014
    AR
    Sometimes if you crack one loose just barely in the tightening direction instead, they will break free. I usually use another wrench on the end of the first because I'm old and don't like mashing hard on wrenches anymore. Thats a good opportinity to slip and become injured, or break a tool too. But sometimes its the only way. PB usually gets em all if you give it time. If not, yep heat or chop chop.
  15. #15 Re: High Pressure line stuck
    im not 100% sure what line is what, but i did find i had to take the one thats in the wide open off first to get the line thats behind it off. theres no good angle to it if the other line is in place.
  16. #16 Re: High Pressure line stuck
    Feb 2015
    Monticello, MN
    Lol yupp, I weigh like 154 lbs with tool belt and work boots on. Luckily, the pressure line is the one thats in the wide open. Thats what I seen also is the back one is trapped in there. Im still just waiting to hear back to see if I get lift time, if not ill be back at it next weekend. This isnt fun anymore lol. Ive also had good leverage, I used a big pipe but it didnt give me much turning room. But Ill find another that just barely fits over the wrench and gives me more room
  17. #17 Re: High Pressure line stuck
    Cibolo, TX
    Damn son, I weighed like 180 in high school, lol. Maybe put a glove on, too, might help you give it some more force if you're not afraid to smash your hand against stuff when it pops.
  18. #18 Re: High Pressure line stuck
    SWPA
    When I was his age I was lucky to weigh 145. 15 years later I'm still not big by any means, but float between 170 and 180 lbs, but am a ton stronger than I was. LOL
  19. #19 Re: High Pressure line stuck
    light weight for sure....i was 150 in 7 th grade easy. graduated at 225.
  20. #20 Re: High Pressure line stuck
    SWPA
    Other than the sales reps I am one of the heavier guys at work LOL
  1. how to replace PS pressure line
    By nastypvp in forum General Tech Discussion
    Last Post: 02-23-2015, 01:22 AM
  2. Fuel line pressure
    By gtpsgofast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2013, 08:01 PM
  3. Power steering high pressure line 04+
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2011, 09:37 AM
  4. Help with Line pressure setting
    By OrangeL67 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2011, 06:57 PM
  5. A/C low pressure line location on 98 GTP
    By Juanmiguel in forum General Tech Discussion
    Last Post: 02-26-2010, 10:02 PM
