Thread: car won't start...
Results 1 to 7 of 7
  1. #1 car won't start...
    Sep 2014
    Lexington, MI
    Alright here's the deal. Went to start my car this morning with my remote start (avital 5303) and it worked perfectly and about 5 min later the car turned off. Went to start it again and nothing. all of the lights light up but when I go to turn it over it just clicks. Tried jumping it and nothing happened. Is it the starter, plugs and wires, or coils.
    2000 GTP ZZP pcm, drilled/slotted rotors, homemade intake
  2. #2 Re: car won't start...
    Feb 2013
    37.295091, -121.930053
    well what code is it throwing? thats were we need to start
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: car won't start...
    Sounds like a ground came loose.
    If the starter just clicks there usually is a grounding problem, the car could shut off for the same reason as it wouldnt charge the battery.
    I'd start there.
  4. #4 Re: car won't start...
    Sep 2014
    Lexington, MI
    Just ordered a OBD ii bluetooth scanner for the torque app. hopefully it's not anything to big. Is there any possibility it could be a fuse or ignition relay? Also I'm in Michigan and it got down to - 27 degrees last night
  5. #5 Re: car won't start...
    sounds like a dead starter. what mine did, just a click in the dash, and no crank. try hitting the starter with a hammer while someone holds the key to start. if it cranks over after hitting it, the starter is bad.
  6. #6 Re: car won't start...
    Sep 2014
    Lexington, MI
    Any recommend starter. I generally get all my stuff from rockauto
  7. #7 Re: car won't start...
    google for a local starter / alternator re builder. most of the time they are cheaper then the parts store, and you got a local warranty with it. if they dont have one to exchange for your old one they can rebuild it in like a hour most of the time.
  1. 06 Base Rough Start with Auto Start
    By jenebo in forum 04+ Specifics
    Last Post: 08-30-2016, 11:24 AM
  2. Installing remote start on non-remote start car
    By GPmanter in forum General Grand Prix Discussion
    Last Post: 01-29-2016, 11:39 AM
  3. 1993 grand prix 3.4 wont start have to pump gas to start
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-27-2015, 05:45 AM
  4. how to>new fob for auto start, already have auto-start installed
    By Timmaayy2121 in forum Introductions/Noob Questions
    Last Post: 12-20-2014, 06:53 AM
  5. Won't Start
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 01-20-2011, 04:00 AM
