Thread: Interior lights, drl issue
Results 1 to 9 of 9
  1. #1 Interior lights, drl issue
    Dec 2012
    Oswego, Illinois
    As I was driving at 12 am today, I pulled into a McDonalds and when I was under the street lights my automatic lights (drl, dash lights, heating and ac) all turned off and would not turn back on. When I opened my door to get out the car made the chiming noise like my lights were left on. Does anyone know why or what caused this? Also, my horn went off by itself earlier in the day if that may have any ties. Any help much appreciated!
    2002 GTP: My Daily
    Wizaired CAI
  2. #2 Re: Interior lights, drl issue
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    I would almost say have your clock spring examined; but headlamps are not connected through the clock spring... however, they are connected to the body control module (BCM), and those have a nasty habit of not only going bad but making your car go haywire in the process! If you start to have other bizarre misbehaviour from your car, the BCM is where I'd go! But make sure it's the culprit before throwing down a couple hundred dollars (parts alone!) for a new module...
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  3. #3 Re: Interior lights, drl issue
    Dec 2012
    Oswego, Illinois
    Thank you for the reply! Ill definitely keep those in mind. This isn't something that I should not be driving on is it?
    2002 GTP: My Daily
    Wizaired CAI
  4. #4 Re: Interior lights, drl issue
    Dec 2014
    Moline, IL
    I have a coworker whose '02 Grand Am fried its BCM and left her stranded. She had to have it towed; if you have no choice but to drive it until you get it fixed, then try to nurse it along. Otherwise wait until you can get it looked at/fixed...
  5. #5 Re: Interior lights, drl issue
    Dec 2012
    Oswego, Illinois
    Alright. Again thank you for the info!! I'll just have to play it safe
    2002 GTP: My Daily
    Wizaired CAI
  6. #6 Re: Interior lights, drl issue
    Dec 2012
    Oswego, Illinois
    Update - Today I also realized that my tail lights are not going on either. Brake lights work fine, just not the tail lights. I took a look at the fuses and replaced the 10a for DRL to see if that would help, but it did not. Does this Still sound like a BCM issue?
    2002 GTP: My Daily
    Wizaired CAI
  7. #7 Re: Interior lights, drl issue
    Dec 2012
    Where 4T65E's were born
    What kind of car do you drive? Different cars have a different electrical systems/controls/features
    Sold.
  8. #8 Re: Interior lights, drl issue
    Dec 2012
    Oswego, Illinois
    02 GTP sorry forgot to mention that previously
    2002 GTP: My Daily
    Wizaired CAI
  9. #9 Re: Interior lights, drl issue
    Jan 2014
    AR
    I'm not much on electrical diagnosis but just don't forget checking basics like bulbs and grounds.
    Things I would check first are tail light bulbs and connectors at the DRL module and headlight switch. Maybe someone previously unplugged the DRLs and didn't get it plugged back in good. The horn blowing by itself is wild though. I would probably also check connections to the steering column. For like the combo and ignition switches, horn. Wonder if an animal has attacked your harness somewhere, or if moisture is getting somewhere it isn't supposed to behind the dash. Look your harnesses over real good for physical damage and wetness.
  1. interior lights
    By torirose145 in forum Introductions/Noob Questions
    Last Post: 06-03-2013, 12:32 PM
  2. Electrical issue - interior lights
    By JoeBlood in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2012, 07:01 PM
  3. Interior Lighting Issue
    By RaiderGT in forum General Tech Discussion
    Last Post: 01-30-2012, 08:55 PM
  4. interior lights/exterior lights newbie question
    By spider4 in forum General Tech Discussion
    Last Post: 11-10-2011, 08:34 PM
  5. LED interior lights
    By joliver2011 in forum Visual/Body Modifications
    Last Post: 02-14-2010, 09:45 PM
