Thread: ls swap in a gtp
Results 1 to 20 of 22
  1. #1 ls swap in a gtp
    Jan 2015
    ohio
    I've looked and looked and somehow I can't find what I thought would be a common question. Can I put a ls motor in my 98 gtp? It's tax time and a come across a totaled 05 gxp for real cheap. Anyone done this or know if it can be done? I assume it would since its coming out of a car offered with a 3800.
  2. #2 Re: ls swap in a gtp
    Mar 2012
    NC
    Quote Originally Posted by jcleary82 View Post
    Anything is possible if you have the time and money. The engine will fit...with a minor amount of fab work. Wiring it and making it play nice is the pain.
  3. #3 Re: ls swap in a gtp
    GTP Level Member
    Jan 2015
    Lincoln, NE
    measure the distance between the frame rails of yours and then measure the distance on the GXP. probably just need the cradle too.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  4. #4 Re: ls swap in a gtp
    Apr 2012
    Bancroft. Ontario, Canada
    go for it.
  5. #5 Re: ls swap in a gtp
    Making it run and function is going to be hard.
    I wouldnt do it personally.
  6. #6 Re: ls swap in a gtp
    were talking fwd still? some dude did a 427 monte that was a magazine feature.
    http://www.lsxtv.com/news/this-monte...be-lethal-too/
    mind you this is a money no option build.
    If I knew what I do know 2 years ago id buy a bonnie GXP and yank the N* and and have a turbo 3800 powered Bonnie with a 4t80 transmission.
  7. #7 Re: ls swap in a gtp
    You will also need to beef up your trans as it was made to barely handle the power put out by a 3100 v6 let alone a 5.3l v8.
  8. #8 Re: ls swap in a gtp
    Jan 2015
    ohio
    I'd love to go for it. Just can't find any support in case of trouble. I'm a decent mechanic, but by no means a professional. Regardless of doing the swap, I was still going to buy the car for 1000 to make money on it. I was sitting here when the idea dawned on me. If it's do-able, then why not if I'm going to have everything. I was just curious if it would bolt in without any fab work. I'm sure painless wiring could whip me up a harness for a few hundred bucks.
  9. #9 Re: ls swap in a gtp
    turbo 3800s are way less problem to get running and making solid results rather than trying to swap rewire it and get it running right.
  10. #10 Re: ls swap in a gtp
    Quote Originally Posted by 98NormalNameVet View Post
  11. #11 Re: ls swap in a gtp
    Jan 2015
    ohio
    From my understanding, the transmissions are the same. If not, I have the one with the original car.
  12. #12 Re: ls swap in a gtp
    They are completely different yet almost the same.
    Confusing right.................sorta.
    NON gxp transmissions have a different trans case. GXP's use a special case because of the flywheel/starter setup. The internals are also different between 97-02 and 03+ cars, they got upgraded parts. Also the GXP's have a TCM (transmissin control module) that is unique to the GXP because it has a 5.3 V8 motor with a completely different power control module (PCM).
  13. #13 Re: ls swap in a gtp
    May 2008
    Schuyler, NE
    The main difference is, the 5.3 uses a different bell housing.
  14. #14 Re: ls swap in a gtp
    May 2008
    Schuyler, NE
    Well I should have hit refresh before posting.
  15. #15 Re: ls swap in a gtp
    GTP Level Member
    Jan 2015
    Lincoln, NE
    if you had the car the engine wiring part wouldnt be that hard i dont think. just knowing the little bit i know about LS swaps creating a stand alone engine harness is not that hard if this is similar to all the other LS stuff. the **** part would be making all the stuff in the cab of the car work correctly. IE your gauges and what not.
  16. #16 Re: ls swap in a gtp
    Like I said turbo a 3800 then save and save and save some more for a triple edge performance transmission........
    Turbo 3800 can make 450hp + pretty easy.
  17. #17 Re: ls swap in a gtp
    At the end of the day a turbo car would cost less and blow the doors off an ls swapped gp.
  18. #18 Re: ls swap in a gtp
    http://www.fastfieros.com/projects/tomkls1/tomkls1.htm
    That was done before the ls4 even existed.
  19. #19 Re: ls swap in a gtp
    Jan 2015
    ohio
    So basically, it's a direct bolt in, minus the wiring? I'll have 2 complete cars. I should be able to pull both wire harnesses and have painless make one. I had an old friend that did that on a ls6 blazer, and it was surprisingly cheap.
  20. #20 Re: ls swap in a gtp
    If you can make a harness and have the whole donor car sure the rest would be easy. Swaps go to hell and get overly complicated when people are trying to do things from scratch. Use as much oem components and wiring as possible.
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
