Thread: Help: Having trouble after header install
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Help: Having trouble after header install
    Jan 2015
    United States
    Hi guys,
    I have a 97 GTP and just installed aftermarket headers, crossover, midpipe, held together by band clamps and u clamps, I also replaced the rear o2 sensor. After the header install, I can't rev past 4k RPM in park or neutral and supercharger sound is gone. Also, the car bogs down going up hill 45mph and I feel like I have lost power on acceleration.
    Weird thing is, I wasn't getting any reading from the MAF sensor and got the P0102 code right after header install. I fixed this by replacing the 21 fuse. The only reason I can think of it blowing this fuse is the precat o2 sensor wire was touching the rear header, I can not think of any other reason.
    Right now, I am getting reading from front and rear o2 sensors AND the MAF and everything looks correct.
    I do know there is an exhaust leak from the mid pipe near the rear o2 sensor. Only one bolt in the flange as the other bolt was seized and snapped off when taking it out. I doubt this is what could be causing it, but just wanted to throw that out there. No other exhaust leak that I know of.
    I personally think it could be a vacuum leak or maybe I put a vacuum line in the wrong place? I took apart a lot of the vacuum lines, does any one have a good diagram to see where each vacuum line goes? Or does any one have any idea what could be causing this problem? No check engine lights yet, although I am expecting the p0420 code to pop up anytime now
  2. #2 Re: Help: Having trouble after header install
    your hitting the rev limiter in park. its normal.
    and you loose boost psi with headers if you had 7 or 8 stock you'll have 5 now. the o2 wire would blow the fuse if it melted and then making the maf not work and could be why it was dogging up hill.
  3. #3 Re: Help: Having trouble after header install
    Jan 2015
    United States
    Thanks for the reply. I am fairly new to superchargers. I did not know that headers would cause me to loose boost.
    As for trouble going uphill, this was after fixing maf.
  4. #4 Re: Help: Having trouble after header install
    spray the vac lines with carb cleaner, if the idle jumps you found your leak, if it has one. make sure your plug wires are back on right too.
    its not that you lost power, its just flowing better, less restriction so the boost number drops.
  5. #5 Re: Help: Having trouble after header install
    Nov 2014
    South Carolina
    if it is still on the stock tune maybe that's the issue? Needs a tune?
  6. #6 Re: Help: Having trouble after header install
    no tune needed for just headers.
  7. #7 Re: Help: Having trouble after header install
    Nov 2014
    South Carolina
    not trying to thread jack but why do you lose boost after headers? loss in back pressure or?
  8. #8 Re: Help: Having trouble after header install
    Mar 2012
    NC
    Quote Originally Posted by gtpwannabe View Post
    Increased engine efficiency = less boost. That's why we pulley down in the SC world...to get back the boost we lost during increases in efficiency. We do NOT go to a smaller pulley just to increase from say 8psi to 14psi...because you really gain nothing from that other than KR with the SC.
  9. #9 Re: Help: Having trouble after header install
    stock i had 8 psi. 1.95 rockers and headers left it at 5.3 psi. 3.4 pulley put it to 10, 12 when its cold out.
  10. #10 Re: Help: Having trouble after header install
    Aug 2013
    McDonald PA
    Forgot the 4 degrees of knock lol
  11. #11 Re: Help: Having trouble after header install
    i had 8* stock, so im ahead of the game lol
  12. #12 Re: Help: Having trouble after header install
    Jan 2015
    United States
    Ok I can understand the loss of boost but when I accelerate, car doesnt accelerate smoothly as it used to and bogs down under throttle. I'm fairly new to superchargers and I know since it's belt driven, exhaust gas isnt recycled... but if there was a leak in the crossover pipe or the exhaust manifold, could it cause this?
    It is stock tune.
  13. #13 Re: Help: Having trouble after header install
    id be looking for a plug left off, or a busted vac line. a leaks not good, but that should not make it feel weak.
    plug wires being crossed up can make it feel weak, sometimes they idle ok crossed.
  14. #14 Re: Help: Having trouble after header install
    if that o2 wire is melted it may not be working. repair the melted wire area. no o2 working will make the engine over fuel.
  15. #15 Re: Help: Having trouble after header install
    Nov 2014
    South Carolina
    in the original post he said that he fixed the o2's and that they are working.. so that can't be it if the o2's are working properly..
  16. #16 Re: Help: Having trouble after header install
    it dont say he fix a wire. the fuse blew for a reason.
    quote: Weird thing is, I wasn't getting any reading from the MAF sensor and got the P0102 code right after header install. I fixed this by replacing the 21 fuse. The only reason I can think of it blowing this fuse is the precat o2 sensor wire was touching the rear header, I can not think of any other reason.
  17. #17 Re: Help: Having trouble after header install
    Jan 2015
    United States
    Yes both o2's are working. Rear is def working, brand new. Pre cat o2 I am def getting constant readings. I reinsulated the wires and tucked them safe. I know for sure its not crossing of plug wires. I actually crossed the rear ones and it misfired. I made sure each wire went to correct cylinder.
    I have a feeling I didnt put vacuum lines in the correct place. I actually broke plastic vacuum line that is located on the passenger side that runs along close to the windshield cowel. I fixed that line but I could have connected it to the wrong place? Can anyone post pictures of their engines with close ups of vacuum lines?
  18. #18 Re: Help: Having trouble after header install
    the line from the top of the sc to the fire wall is what powers your hvac controls.
    make sure all the evap lines are good and the one to the map. you may have leaned on them and snapped one.
  19. #19 Re: Help: Having trouble after header install
    Nov 2014
    South Carolina
    You said the rear o2 is brand new right? Is it bosch ? Heard that bosch o2's are garbage..
  20. #20 Re: Help: Having trouble after header install
    Jan 2015
    United States
    Yes rear is brand new bosch but the rear sensor doesn't effect drivability. Waveform looks good, obviously it's out of range bc no cat
  1. Trouble codes after header install
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2011, 04:13 PM
  2. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. Header Install
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2009, 11:12 PM
  5. S&S Header Install
    By GRANDPRIXFOOL01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 09:57 PM
