I will be getting back at it this weekend.
Check the lead spacer between the two positive battery cable at the battery. Pry it out of the cable end, if it looks burnt that's the problem. The lead spacer has to be removed from the cable end to inspect the lead surface and cable cavity. Acdelco has replacement spacers.
I'd check all your power and grounds. Clean ground areas replace wires if cracked and corroded. Look up the big 3 mod.
Sent from my QTAQZ3 using Tapatalk
are you sure its not hydrolocked from coolant in cylinders from blown gaskets?? my wife has a 98 gt ,the plastic intake cracked and filled the cylinders with coolant. all it would do is click loudly ,then i knew what happened! thank you dexcool!!
