you test for power at the starter little wire yet?
or try to jump the starter? you bridge the little stud to the pos cable stud, it will spark, and then the engine will crank. if the key is to run, it will fire up.
that little wire is what tells the starter to work. you turn the key 12 volts go to that little wire and the starter kicks over.
