Thread: advice on 98 gtp hvac evaporator core replacement
Results 1 to 4 of 4
  1. #1 advice on 98 gtp hvac evaporator core replacement
    Jan 2015
    florida
    the pontiac shop manual is very brief, remove firewall screws, remove screws attaching to dash, and remove case. Is it really that simple?
    how many and where are all the screws under the dash. I have seen post that were mid operation, people droping steering column, and other serious dash disassembly, but never saw post of of someone that actually got it out.
    thanks
  2. #2 Re: advice on 98 gtp hvac evaporator core replacement
    aint that on top of the heater core in the middle of the dash? my guess is its a few steps past the heater core swap.
  3. #3 Re: advice on 98 gtp hvac evaporator core replacement
    Jan 2015
    florida
    heater core swap is done leaving the case in the dash, the bottom of case is removed and heater core dropped. Evap requires complete case removal and top of case is removed.
    actually now that I cracked open the manual again, it does say cross vehicle beam must be removed. and that is much more involved.
    and there is a little picture of evap and 3 bolts under dash, So I think I got my answer, I need to slow down and read more carefully.
  4. #4 Re: advice on 98 gtp hvac evaporator core replacement
    sounds like your taking the dash off too. others who have done it said its pretty easy to do. the whole dash removal part.
  1. Heater Core Replacement
    By Explicit_Spade in forum 04+ Specifics
    Last Post: 01-22-2025, 10:21 PM
  2. Heater Core Replacement 97-03
    By Jakescoots in forum How To Write-Ups/Tech Tips
    Last Post: 01-20-2022, 05:21 PM
  3. ZZP Ic core replacement
    By oldsman105 in forum General Grand Prix Discussion
    Last Post: 04-11-2016, 10:56 PM
  4. Things you might want to know about replacing the evaporator core
    By techweenie in forum General Tech Discussion
    Last Post: 08-16-2011, 09:07 PM
  5. Heater core replacement....
    By m0ng00se in forum General Tech Discussion
    Last Post: 11-19-2008, 10:10 PM
