Thread: I can hear my washer... but still no fluid!
Results 1 to 13 of 13
  1. #1 I can hear my washer... but still no fluid!
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    I'll start off and say I already know I have the crappy 32-degree F formula in my bottle; nothing I could do about that as that's how the car came. But it's considerably warmer right now, and the bloody thing's still not squirting! I hear a high-pitched whir, as if it's on empty, which is nonsense, since it's literally filled to the brim! And-and I checked-there's no fluid leaks, so no loose or burst line. So: what problems do all of you know regarding these washer pumps... or do I have to wait til spring for the darn thing to work properly again?
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  2. #2 Re: I can hear my washer... but still no fluid!
    Feb 2013
    37.295091, -121.930053
    try blowing the line and nozzle out with air. or remove the nozzle and see if its flowing right
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: I can hear my washer... but still no fluid!
    Dec 2014
    Could be a frozen or clogged line
  4. #4 Re: I can hear my washer... but still no fluid!
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    i have a feelings its still frozen somewhere in the line.
  5. #5 Re: I can hear my washer... but still no fluid!
    Dec 2014
    Moline, IL
    I'd opened the lines before the jets, so I know if it's just a blockage, it's upstream; not that the jets get a free pass, but at least they're not the culprits! Jeez: I'll have to get dirty then, and root around in the wheel well... unless there's an easier access point where the line leaves!
  6. #6 Re: I can hear my washer... but still no fluid!
    Dec 2014
    Moline, IL
    It's well above freezing... and I can safely say I've got a rupture somewhere; my bottle's less than half-full now, and not a single drop ever reached the windscreen! At least there's the holiday weekend to tear it apart & figure out what broke!
  7. #7 Re: I can hear my washer... but still no fluid!
    Enfield, CT
    I think the line is busted somewhere
  8. #8 Re: I can hear my washer... but still no fluid!
    Dec 2014
    Moline, IL
    Got a new pump, a salvage line; guess what I get to do in the morning?
  9. #9 Re: I can hear my washer... but still no fluid!
    Enfield, CT
    Quote Originally Posted by April Thompson View Post
    Hmmm go to work and support the lazy democrats? LOL
  10. #10 Re: I can hear my washer... but still no fluid!
    Dec 2014
    Moline, IL
    Well... all of a sudden this "minor repair" has turned into a comedy of errors; the pump I'd bought, touted as OEM, is not! And no other box store has anything but universal, which I refuse to accept. So, I have to wait til tomorrow (at least I have Martin Luther King Day off, working in a school setting) for the only surviving local parts store to open, before going to Rock Auto... but at least I know Anco has a direct-fit part (6712).
  11. #11 Re: I can hear my washer... but still no fluid!
    the line runs up the pass side fender to the cowl under the windshield, if 1/2 the res went dry and nothing hit the window theres a puddle on the ground. look for it. the line is hard plastic and can crack easy. a frozen line could split for sure.
    if you take the pass side head light out you can see the pump and the line and maybe get to the pump and its line easier. if its not whining like it should when you hit the washer lever.
    if you do find a broken line you can fix it with normal vacuum line. cut the broken part out, then push the hard lines into the vac line. vac line is a buck a foot tops.
  12. #12 Re: I can hear my washer... but still no fluid!
    Dec 2014
    Moline, IL
    I belatedly discovered the access through the headlamp... sucks not having a shop manual! But I've got it all sorted now; involved loads of cleaning sediment and sludge out of the lines, nozzles and the pump! In the end didn't cost me a penny (not including new fluid)...
  13. #13 Re: I can hear my washer... but still no fluid!
    nice.
  1. No Washer Fluid
    By Crocitto49 in forum General Tech Discussion
    Last Post: 10-18-2013, 08:40 PM
  2. low washer fluid pressure?
    By Adasm in forum General Tech Discussion
    Last Post: 12-30-2012, 05:37 PM
  3. Windshield washer fluid
    By flyboyray1 in forum General Tech Discussion
    Last Post: 03-18-2010, 10:07 PM
  4. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  5. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
