Thread: how to install after market head unit- steering wheel controls,
Results 1 to 19 of 19
  1. #1 how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    i have the pac- rps- gm11, wire harness for the steering wheel controls ect... i had everything hooked up, radio working, and so on, when i would hit the steering wheel control, the volume or any other one, it doesnt work, but the blue box from the wire hardneess LED light would light up as if it was getting the signal from hitting the steering wheel control, but they wont work.... anyone know what i should do or y its doing this, i tried programing it, didnt work, its like its getting the signal but not making it work, could the wire harness be bad?
  2. #2 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    So lost
  3. #3 Re: how to install after market head unit- steering wheel controls,
    What stereo are you trying to use? With that adapter the stereo must have the input for a wired remote.
    If you look at this pic you see the 2 plug ins that look like a head phone jack? One is the line in/mic port and the other is for an external remote. Your head unit must have this one. The line in/mic port will not work. I have that same adapter in my Hoe and everything works just like it should.
  4. #4 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    i have a jvc-kw-v-20bt
  5. #5 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    its has av-in, av-out, & mic, will this work? i tried pluggin that thing into all 3 of those, n it didnt work, wen i would press like volume on steering wheel control, the box led light would light up, but volume wouldnt work,,,, did u have to program urs?
  6. #6 Re: how to install after market head unit- steering wheel controls,
    I do believe with that stereo you have to connect the blue/yellow wire to something. Idk what but you have to connect it to the stereo somewhere.
    -Edit- You need to connect the blue/yellow wire from the adapter to the blue/yellow wire on the stereo. I do not believe you need to plug in the 3.5mm jack.
  7. #7 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    did u have to program urs??? or did it just work? also i am getting signal wen i press controls on steering wheel on the adaptor so i know its working like wen i hit the volume button, i can see the adaprot led light light up so i know its getting the signal from the sterring wheel button
  8. #8 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    i have everything plugged in too, the radio works,chimes work, and everything, just not the steering wheel controls......
  9. #9 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    what wires do u NOT have connected together?
  10. #10 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    the only wires i do not have together from the RP5 apaproter to the stero are the solid blue(power antena) & the oragne and white
  11. #11 Re: how to install after market head unit- steering wheel controls,
    It just worked on mine. You connected the blue/yellow wire from the adapter to the blue/yellow wire from the stereo?
  12. #12 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    the blue/yelllow has been connected...
  13. #13 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    also i dont have a blue/yellow wire... i have a solid blue, and a solid yellow, but no blue/yellow as one wire...
  14. #14 Re: how to install after market head unit- steering wheel controls,
    I don't remember what wires I dont have connected.
    You should have a blue/yellow wire that comes out right by the 3.5mm jack on the adapter and there should be one in the harness for the radio.
    I'll go snag some pics of mine.
  15. #15 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    Got it
  16. #16 Re: how to install after market head unit- steering wheel controls,
    Got what?
  17. #17 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    i think i just had somin plugged in that i didnt need to have plugged in... so now im going to attepmt the back up camera
  18. #18 Re: how to install after market head unit- steering wheel controls,
    So the swc are working now?
  19. #19 Re: how to install after market head unit- steering wheel controls,
    Oct 2014
    Cle
    yea all good man thanks a lot!!!
  1. After Market HU that does not lose steering controls/ AUX Install.
    By Eddie298 in forum Audio, Security & Visual Electronics
    Last Post: 06-04-2012, 11:30 AM
  2. Steering wheel and after market head unit compatibility question
    By CRASHMAN55 in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2012, 05:23 AM
  3. 2001 GTP steering wheel controls and fac amp install double din?
    By blazed16 in forum Audio, Security & Visual Electronics
    Last Post: 03-15-2012, 07:49 PM
  4. Head unit mounting kit, and Steering wheel controls
    By BlackGT1 in forum Audio, Security & Visual Electronics
    Last Post: 09-24-2011, 05:07 PM
  5. Head Unit Steering Wheel Controls
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 03:05 AM
