Thread: speed daddy headers
Results 1 to 7 of 7
  1. #1 speed daddy headers
    Jun 2014
    Alabama
    About to install some headers on my buddies gtp, what exactly needs to be done with the headers flexpipe and what clamps do I need and how many?
  2. #2 Re: speed daddy headers
    2, 2.25 and 2, 3 inch band clamps. clearance the fire wall for the o2, and add a o2 extension or make one.
    follow billboost37's header install how to.
  3. #3 Re: speed daddy headers
    Remember that if you make an o2 extension harness you need to make it before the o2 sensor harness, if you cut and splice the harness for the o2 sensor the o2 sensor will no longer work.
  4. #4 Re: speed daddy headers
    Quote Originally Posted by Slick2500 View Post
    AKA cut the car side o2 plug off, add 3 feet to it. run the new wire down the pass side fender to the rack area, then to the o2 sensor.
    if you try going the short way chances are the wires will get melted.
    i zip tied the wires to the vac line on the fire wall.
  5. #5 Re: speed daddy headers
    Aug 2014
    North Alabama
    Its my car. About the flex pipe, do you replace it with a new higher quality flex pipe section or do I just get my local muffler shop to weld in a solid pipe. I dont want it blowing out on me like theyre known for.
  6. #6 Re: speed daddy headers
    you can have the flex replaced before installing, (as well as have the U bed taken out too) snow flake did a how to on it. in the free headers thread.
    or just run it as it. its up to you and your budget.
  7. #7 Re: speed daddy headers
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    i have 3 sets of them running between me and 2 friends, couple years on all of them and they are all just fine as they came out of the box still. Definitely do not put a straight pipe in for the flex. It won't work, it needs to have some wiggle room.
    04 GTP -HAI, 1.9 rockers.
  1. Speed Daddy Headers or...?
    By hammerline81 in forum General Tech Discussion
    Last Post: 08-04-2017, 11:56 PM
  2. Speed daddy headers
    By GrandPrix06GT in forum Wanted To Buy - Parts
    Last Post: 12-02-2014, 05:07 AM
  3. Looking for Speed Daddy Headers - '98
    By NinetyEightGTP in forum Wanted To Buy - Parts
    Last Post: 03-27-2013, 09:07 PM
  4. speed daddy headers
    By sic40th in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:07 PM
  5. Speed Daddy Headers
    By Vioarr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2010, 03:29 PM
