Thread: Back to the code game
Results 1 to 20 of 50
  1. #1 Re: Help! Many codes and misfiring, Icm maybe?
    St. Louis
    The sensor before the MAF should be the IAT sensor (intake air temp). You could have the ICM tested but often they show good even if they aren't. If you have a spare ICM laying around then swap it in and install your existing coils. If you still have a miss then start by replacing the coils 1 at a time until it goes away. If you replace the entire ICM and all 3 coils all at once you will never know which part(s) are bad.
    They are a wierd size, and the 5.5mm is correct, but you can also use a 7/32 socket to get them out. I use it all the time. And don't have to he-man them on, just snug will work.
  2. #2 Re: Help! Many codes and misfiring, Icm maybe?
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Quote Originally Posted by FordMan77 View Post
    thanks fordman. I was going to try to get that one coil out that i coudnt yesterday and swap with other gtp in driveway (the crap one with over 300k, But never has major issues lol) I used 7/32 to get the rest out. with out issue.the bolted has been totally rounded by past owner so im going to just try to get my multi-tool out a try to cut to get a flat head screw driver in there. or i i mite just get the angle grinder out and cut the whole coil out with screw. but we will see.
    again thank you Fordman for the advise! keep it coming
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  1. 05 Misfiring
    By PontiacL32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 11:34 PM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. Misfiring
    By beetlebugman in forum General Grand Prix Discussion
    Last Post: 08-29-2012, 08:08 PM
  4. misfiring
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 09:22 PM
  5. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
