Thread: Reverse top swap
Results 1 to 9 of 9
  1. #1 Reverse top swap
    Apr 2014
    Ft. Wayne, IN
    So I am looking at normal top swap posts, and it doesnt say you had to change the fuel lines, etc. I am trying to hook up supercharged fuel lines to an l36 fuel rail, and it wont connect. Even bent out the tabs a little bit to see if that was the problem.
    Thoughts?
  2. #2 Re: Reverse top swap
    Jul 2014
    New Jersey
    Maybe you're hooking them on the wrong side idk
    They should have the same fitting my l36 fit the l67 rail
  3. #3 Re: Reverse top swap
    you need to use l67 fuel rail on the engine. the l36 rail wont fit as the injectors are in a different place.
    what year car are you top swapping?
  4. #4 Re: Reverse top swap
    hangover park IL
    you need to remove the plastic clips on the NA fuel rail fittings. the NA hoses have plastic ends and two tab clips, that you can remove with the std tool or with just your two fingers.... while the SC has stainless ends and "tool only" clips/teeth.
    because people remove em via the finger method the plastic clips stay on the rail nipples
    ~James~ Psychotic Gearhead
  5. #5 Re: Reverse top swap
    Apr 2014
    Ft. Wayne, IN
    I removed the plastic. L67 fuel lines still dont slide on. And can't get a l67 rail to fit on a NA engine
  6. #6 Re: Reverse top swap
    hangover park IL
    yeah the NA rail sorta requires a 90* elbow on the return near the thermostat...the sc lines may not reach over there without kinking the plastic hose
    you may need to ditch the oem lines and run braided line and AN fittings with quick disconnects
  7. #7 Re: Reverse top swap
    Apr 2014
    Ft. Wayne, IN
    They reached just fine, just wouldn't secure. I figured they were interchangable due to not seeing anything special with adding supercharged rails to non-sc cars.
    AN fittings are out of the question. Not spending $200 to make NA rails fit. Rather just get all new pines from the junkyard for $5. Pretty sure they disconnect under the car anyway.
  8. #8 Re: Reverse top swap
    hangover park IL
    the clips inside your ends may be damaged
    you can buy the ends in a fuel line repair kit and use a pic to remove the new units guts/orings and swap em into your fittings... at least then you eliminate the orings as a possible fire hazard
  9. #9 Re: Reverse top swap
    Apr 2014
    Ft. Wayne, IN
    They snapped right back onto the supercharged lines while trying to compare them. They also never leaked. Im assuming they wont work and will try to get a NA setup for it.
  1. 04 + Reverse bar
    By mgborgo1575 in forum 04+ Specifics
    Last Post: 11-11-2014, 12:27 PM
  2. Reverse Top swap
    By SnowTh1ef in forum For Sale - Parts
    Last Post: 05-14-2014, 12:35 AM
  3. 01 Transmission no reverse
    By Zack in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-24-2013, 03:12 PM
  4. Need a little help with reverse wire
    By christopher8911 in forum Audio, Security & Visual Electronics
    Last Post: 08-17-2010, 06:15 PM
  5. reverse
    By gotboost3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2009, 11:23 AM
