Thread: Back to the code game
Results 1 to 20 of 50
  1. #1 Re: Help! Many codes and misfiring, Icm maybe?
    St. Louis
    You could have a bad MAF. If you unplug the MAF and start the car and it runs better then I would suspect it. Don't unplug the MAF with it running. When unplugged it may take a bit of feathering of the throttle to get it to run until the PCM catches on and runs off it's premapped tables.
    Don't drive it hard w/ the MAF disconnected and stay out of boost for sure.
    I don't have a link offhand to what the normal values are. I'd have to find them on here somewhere. Before I forget again, what year GTP are we dealing with?
    On the coil pack with the stripped screw, is it the screw itself that is stripped or the ICM plate that it bolts to?
  2. #2 Re: Help! Many codes and misfiring, Icm maybe?
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Quote Originally Posted by FordMan77 View Post
    with the MAF out and the sensor before it, on the intake.With the MAF off and put in D gave little gas( with brake pedal down) got car up to about 2000 RPMs then starts to misfire. also when i take off the gas when doing that the RPMS get almost so low it stalled. like 400RPM.
    The year is 98. Supercharged.
    Also the coil the has the misfire is also the one with bolt top striped. cant get sockets or vice grips to catch to get to turn.Going to try again in the morning. not sure how but i gotta get it out to Swap with my other GTP (2000). thats how i found out the coil didnt work about three months ago.
    Should I get ICM tested scanned at part store? I hear that sometimes there useless tho.
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  1. 05 Misfiring
    By PontiacL32 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 11:34 PM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. Misfiring
    By beetlebugman in forum General Grand Prix Discussion
    Last Post: 08-29-2012, 08:08 PM
  4. misfiring
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2010, 09:22 PM
  5. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
