You could clean the MAF as well. Just make sure you use actual MAF cleaner (they sell it at parts stores) and not throttle body or carb cleaner or you could damage it.
OK so iv took the MAF out and cleaned that(with MAF cleaner). air fliter. Check two of the three coils. one coil pack has a screw the the top is all striped. any ideas on that? But its all back together and took a ride and car stalled like right after i pulled out of street. couldn't get it to start with out pushing gas pedal down a few times... SO that confused me also. Going to do the spray trick tonite on the wires to see if there are any sparks or anything... i need more ideas! I did clear all codes after i put it back together. When the car missfired and stalled no codes came up.. why would that happen to? Whats my next move??
