take the key out, the wheels locked.
dog bones, the two upper engine strut mounts. take the 2 bolts off the engine side. taking these off will let the engine drop when the rear of the sub frame is lowered.
no need to vac the lines to fill. swap the lines if you want, then hook em all up, then wheels off the ground still, fill the res on the pump, then car off turn the wheels lock to lock 15 times. stop 1/2 way top off the res if needed. then fire it up and top off more if needed.
if your using the old lines, dump some fluid in the res with the lines over a pan. they will drain and flush the res and lines.
