Thread: is there a way to tell if my car has variable steering?
Results 1 to 6 of 6
  1. #1 is there a way to tell if my car has variable steering?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    im looking for a rack and pinion and i cant seem to find out if i have variable steering or not. can anyone help.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: is there a way to tell if my car has variable steering?
    Nov 2012
    Erlanger, KY
    97+ gtp's all had variable steering.. unless someone swapped out the old rack to a non variable steering.
    GT/SE had non variable.
    Easy way to check is where the steering column bolts to the steering rack gear, there is a plug wire coming out of it the steering gear area part.
    If its there, you got variable steering.
    We just bought a non variable steering rack for our turbo car, and the steering gear part section is noticeably smaller then the old one with variable steering.
  3. #3 Re: is there a way to tell if my car has variable steering?
    My GT had variable.
    What now?
  4. #4 Re: is there a way to tell if my car has variable steering?
    Nov 2012
    Erlanger, KY
    Could be wrong on the GT/SE not having them.. either way, just get down there and look for the wire.
  5. #5 Re: is there a way to tell if my car has variable steering?
    Nov 2012
    Erlanger, KY
    Attachment 10240
    Attachment 10241
    Top is non variable while the bottom pic is variable.
  6. #6 Re: is there a way to tell if my car has variable steering?
    It's 1000000 times easier to pull the ABS fuse and see if the steering is heavier at speeds under 10 mph than it is to hunt for a wire in a 10-15 year old car that is probably covered in 10-15 years of road grime.
  1. Non Variable Steering Rack
    By TDgrand in forum Brakes/Suspension/Chassis
    Last Post: 11-07-2012, 02:05 PM
  2. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
  3. does my car have variable assist power steering
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-04-2010, 04:53 PM
  4. steering pop
    By mstowe in forum General Tech Discussion
    Last Post: 06-01-2009, 01:24 PM
