Would this cause the issues ive been having?
Just wanted to update, replaced the battery bolts and cleaned off the terminals. drove it around for about 20 mins and hasnt died yet. hoping it's fixed
Thanks a ton for all of your help, you guys are awesome
UPDATE; Died againSomeone also told me to check a security box of some kind thats behind the dash, does that sound like somthing thatd cause it? he said it might be loose
Another bit of info i ran across is that it could be the ignition switch causing the stalls and loss of power to dash?
you check the ground wires yet? if not look at them.
you would be talking about the ignition harness. anything else acting up, heater fan speed, head lights, cluster lights flashing on and off?
Nothing else is acting up from what i've noticed so far. Other electronics seem fine, car still drives like normal. checked the grounds that i could find but have been trying to find manuals or somthing showing what wires i should look for with not much luck
So i tried following the negative as much as i could. I'm not super mechanically inclined but i guess i should ask. where is the trans bell housing located? i thought i knew but im not seeing anything bolting to it :s
driver side of the engine, on the trans where it meets the engine is a bolt with a stud and 3 wires to it. look where the exhause cross over pipe starts.
ground cable leaves the battery runs across the rad support under the rad to the ground, pos cable takes the same path to the starter.
if you can find the starter, the ground it right next to it. as seen in the diagram i posted.
I found those wires, they seem tight with no corrosion. i couldnt quite take them off to clean them though i lack the tools for it right now.
Are there other grounds i should check? i heard there are some inside the car and in the trunk. Also to clarify if the dash goes off but stereo and other stuff stays on when it dies can it still be a ground?
The stereo staying on piqued my interest... I'm wondering if it's ignition switch related. Like, you know how, when you shut the car off the radio stays on until you open a door. What you're describing sounds like, you're just driving along, and someone turns the key off. (Without the steering wheel locking of course.)
I'm no guru like some of these guys. Just throwing that out there. Is that a possibility?
I thought that could be somthing to look at as well because while researching the issue i found a bad ignition switch had the same symptoms (dash turning off when car stalls). And with a bad ground i would assume that the radio an other things would at least flicker off but they don't :s
Any signs of a remote start or alarm installation/removal? Maybe there's a bad connection somewhere under the dash. Sorry if you already mentioned that. I read the whole thread but don't remember you saying anything about that.
Well the SRS light has been on since i had it and the bottom plastic piece on the steering column has been loose since ive owned it. looks like someone lost the screws for it so it partially sits open
So, somebody's been in there...
Like I said, I'm no expert, and I could be way off. But with nothing else to go on, I would at least inspect all the wiring under that hush panel for cuts and splices. It's not going to cost you anything but some time.
