Thread: P0172 every Winter
Results 1 to 15 of 15
  1. #1 P0172 every Winter
    SE Level Member robstout's Avatar
    cincinnati, oh
    I have 2001 gtp that is completely stock. The car has 220000 miles on it and still runs great. However, every winter it gives me a P0172. I can clear the codes and it will stay off for about a day or so. The car doesn't seem to run any different but my mileage does seem to drop a little. This is the 3rd winter ive experienced this. I have tried replacing all O2 sensors and the maf which seemed to help but the mil always comes back the same code and only that code. Anybody ever experience anything like this?
    Shake-N-Bake!!
  2. #2 Re: P0172 every Winter
    Dec 2012
    Where 4T65E's were born
    You should always identify the code and its meaning so everyone that sees it doesn't have to look it up themselves.
    P0172 - Fuel Trim System Rich Bank 1
    Sold.
  3. #3 Re: P0172 every Winter
    Jul 2012
    Chicago
    She's running rich.
    -Carl
  4. #4 Re: P0172 every Winter
    cincinnati, oh
    What would cause it to run rich only when outside temps get cold?
  5. #5 Re: P0172 every Winter
    I would start with cleaning your MAF, after 220k miles its probably dirty. Check for vacuum leaks.
  6. #6 Re: P0172 every Winter
    cincinnati, oh
    I replaced the maf last winter. The light stayed off for a couple days then came back. Think it could be getting dirty that quick?
  7. #7 Re: P0172 every Winter
    Dec 2012
    Well check the things that determine fuel. Which is maf, map, and more simply engine temp sensor, and iat. Now why just bank 1 I'm confused about.
    Sold.
  8. #8 Re: P0172 every Winter
    We only have 1 bank guy, just 2 sensors for that bank.
  9. #9 Re: P0172 every Winter
    Dec 2012
    I thought it was 2 banks 1 sensor(for fuel trims) lol. I suppose banks are in reference to the sensors and not 1-2 being inline or v engine
    Do you have a stock or open cone intake?
    Sold.
  10. #10 Re: P0172 every Winter
    Nov 2011
    NY
    Why did you replace parts? MAF? Shotgunning parts at problem? That's an expensive way to guess how to fix something. I go with IAT sensor as the code appears when the TEMPERATURE changes, lol... Maybe Bad injector?
  11. #11 Re: P0172 every Winter
    cincinnati, oh
    It has an open cone
  12. #12 Re: P0172 every Winter
    cincinnati, oh
    Quote Originally Posted by coolone View Post
    I replaced the maf due to a maf code I swapped it with a buddies and ot fixed it so I went and bought a new one.
    Ill check the iat and cts when I get a chance. The injector thing makes me wonder cuz I have replaced 2 separate ones that just quit since ive had the car about 5 years. Only car I've ever had that actually had a bad injector twice.
  13. #13 Re: P0172 every Winter
    Dec 2012
    Well as always asked in repetitive maf failures, they can be over oiled and cause issus with contamination. I don't think it would get dirty in a couple days unless you serviced the filter again.
    Injectors may be a good place to start. I've done injector balance tests which is ideal, but that requires special equipment.
    Sold.
  14. #14 Re: P0172 every Winter
    Enfield, CT
    well since it's open cone, is the IAT hanging off by the filter? If so, I'm gonna suggest looking at the IAT especially since you have an issue when the temps are changing.
  15. #15 Re: P0172 every Winter
    The Boss Iceman6669's Avatar
    Jun 2011
    the IAT wont change fueling at all. The IAT will only pull timing.
    2011 F-150 Yote powered
  1. New cam and other mods, and now SES P0172?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2012, 02:36 PM
  2. knock & P0172
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2011, 02:34 PM
  3. 04 GTP Surging and P0172
    By benblank in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2011, 03:26 PM
  4. p0172
    By 02gtp40 in forum The Rant Forum
    Last Post: 05-29-2010, 01:46 PM
  5. p0172
    By awsom83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:00 AM
